Rebel911's Avatar
PLS help identifing my engine
Old 09-02-2009, 05:54 PM
Rebel911's Avatar
bump
Old 09-03-2009, 04:22 AM
want to sell it?
Old 09-03-2009, 04:53 AM
Rebel911's Avatar
that is the plan, you looking to buy? I am going to put it on ebay today after work
Old 09-03-2009, 05:02 AM
Originally Posted by Rebel911 View Post
the engine number is 6399095
thanks for the help.
Well, something doesn't look right but I could be wrong. The 639 indicates it is a model year 1969 911 S but the 9095 indicates they made over 9000 engines with that series. My info shows engine range is 6390001 to 6392126.
Look beside the number and check for the engine type. Should be 901/07 or 901/13
Tony G
2000 Boxster S
Honestly it does not look correct you sure you copied the number correctly?
639001-6392126 are 69 s engines 2.0, your 6399xxx does not compute. They only built 2126 S (the last one I own)
Serial number breaks down as:
First digit 6= 6 cylinder
Second digit = engine type
1=t
2=e
3=s
3rd digit model year
9=69
0=70
1=71
Then the sequential number
Your number is to high 639 (9095)
Old 09-03-2009, 05:07 AM
even the T and E engines did not go that high for a serial number T s stoped at 6198184 and E's at 6298583
Old 09-03-2009, 05:12 AM
Rebel911's Avatar
Old 09-03-2009, 05:18 AM
like Tony said you need to look for the engine type. Should be 901/07 or 901/13.
Can you post a picture of the whole engine?
Old 09-03-2009, 05:27 AM
Rebel911's Avatar
Don't knock the silicone, this is the way I got the engine. I decided to go another route.
Old 09-03-2009, 05:39 AM
Rebel911's Avatar
this is what it cam out of:
Old 09-03-2009, 05:42 AM
its an SC 3.0 engine
Old 09-03-2009, 05:46 AM
Rebel911's Avatar
I am looking to confirm that this is a ROW engine like the rest of the car.
Old 09-03-2009, 05:51 AM
I personally can't tell if it is a 2.7 or 3.0, but it is a CIS injected engine. Someone may have stamped in numbers from a factory replacement case, which does not come with a number. The red shroud and 639 appear to have been intentionally misleading.
YOU NEED TO IDENTIFY THE ENGINE TYPE BY THE NUMBER BEHIND THE SERIAL NUMBER.
Tony G
2000 Boxster S
Old 09-03-2009, 05:54 AM
Rebel911's Avatar
Old 09-03-2009, 05:57 AM
Tony, you are like 5 miles from me. I am off the Lake Rd. in Webster.
There are a lot of p-cars in this area and a great group of track junkies. With Watkins Glen and Mosport so close to us, these historic tracks are a blast to drive.
What engine plans do you have for the car and why not use what you have?
Tony G
2000 Boxster S
Old 09-03-2009, 06:04 AM
Rebel911's Avatar
I currently have two engines and the other one is top secret till it is done.
Old 09-03-2009, 06:10 AM
Well, if you want to know what the other lump is and have the ability to bring it to a shop, go to Eksten's at 78 Bennington Ave. 585.621-8200. Larry is the owner.
(Bennington is off of SR18 behind Kodak....not far from Adrenalin ********)
Tony G
2000 Boxster S
Old 09-03-2009, 06:15 AM
Rebel911's Avatar
thanks
Old 09-03-2009, 06:31 AM
Rebel911's Avatar
Old 09-03-2009, 10:12 AM
