Experience With Dash Installation in '88 Cab?
Anyone ever removed and installed a dash in an '88 Cabriolet? Mine's cracked and is ready for replacement. I hear the windshield doesn't have to be removed.
Any tricks to the removal or is it pretty straightforward?
Old 09-05-2009, 12:11 AM
RETIRED
Joe Bob's Avatar
Yupz......LOTS of nutz.....gotta pull the shield......
2012 ML350 3.0 Turbo Diesel
Old 09-05-2009, 03:14 AM
Are you sure? My mechanic says the windshield doesn't have to be pulled on an '88. Mine's an '88 Cabriolet also. Don't know if that makes a difference.
Old 09-05-2009, 11:08 AM
Formerly known as Syzygy
Canada Kev's Avatar
I read somewhere that when they went with the big vent dash windshield removal was not required. Again this is just hearsay, so I may be incorrect.
Kevin
Old 09-05-2009, 11:58 AM
scottrx7tt's Avatar
there is no reason whatsoever to pull the windshield on the newer dashes. I know, i just replaced mine. If you completely pull out the blower motor, and vents, you can get to all of the nuts easily. It helps too to pull the gauges.
Old 09-05-2009, 01:06 PM
RETIRED
Joe Bob's Avatar
make sure you get a flat rate....no change orders....
I have an 83 and it was a PITA.
Old 09-05-2009, 08:56 PM
Tags
1988 , cabriolet , dash , install , removal
