Will H5's work?????
Can i do a direct pluggin for H5's where my H4's where with no mods?
you will have to change out the pigtails
is that a big thing where can i get them and will they b nice n bright? bright as H4's
As scottrx7tt said, you will need a new connector between the H4 connector and the H5 bulb. There are several ways of doing this. Go to a Pep Boys or similar and buy a connector for 9004/9007 or 9005 bulb. These have pigtails, you need to crimp blade connectors to insert in the female H4 connector.
I will post a picture of what you need, I have this set up in my car. If you will use higher wattage bulbs you can buy ceramic connectors and use a relay kit. By the way I do not like H5s I need more light, I am changing to H1s with 100 watt bulbs and a relay kit. Last edited by donporfi; 10-22-2009 at 02:52 PM.. Reason: added comment |
Unless you need to change out your h4s for regulatory compliance purposes, I too believe that you'll find the h5s to be a step down from the h4s illumination-wise. Better to get some higher wattage bulbs and a relay kit for your h4s from our sponsor and keep using the h4s.
Mine are no comparison to the sealed beam headlights they replaced. Why are you converting from H4s? |
Registered Cruiser
Not sure why you are switching from H4's to H5's. 4's are vastly superior. Most people switch out 5's for 4's, myself included.
87' Carmine Red Carrera - Keeper 82' Silver SC - Sold 79' Gran Prix White SC - Sold 05' Black C2S - Daily driver I have never really completely understood anything. |
This is what you need to use the H5s instead of H4s.
But as said before I do not like the H5s. ![]()
Some one stole my H4's off my car while i was on vacation.
I cant find any under $300. |
Ouch!
If you (still) have the US-spec "sugar scoop" covers, you could pick up "generic" 7.5" round h4 housings. I picked up a used pair of Cibie housings for my '86 for under $50 and, with 80/100 bulbs, couldn't imagine going back to "stock" lighting. |
Registered Cruiser
