Source in US for wheel spacers?
Hi all,
Technically I mean wheel adapters (the kind that do not require longer studs). Can anybody recommend a source for me? I'm after 54mm rear, and 31mm fronts. Thanks, Adam
_____________________ '73 RSR Interpretation ---------------------------------- |
try our host pelican
1975 911S Targa Silver Anniversary Edition |
thanks for your reply... i saw them.. but they aren't in the sizes i require.
google boothe spacers, Kevin
thanks, had a look but the sizes don't match my application.
I could maybe go 1mm or so thinner, but definately not thicker.
Here you'll find them:
http://www.cargraphic.de/stepone/data/downloads/28/00/00/Distanzscheiben.pdf They got an US dealer: Road Sport Supply - Home
Roland 930 Turbo '81 Too many modifications to list |
These guys will make any thickness spacer or adapter (hub centric) you want. Wheel Adapters, Wheel Spacers, Hub Rings, and much more! | Motorsport Technology
Harold '79 930/DP935 (sold) '68 VW 3.3 Turbo Crewcab |
boothe will build the spacer to your needs call him, Kevin
Off subject a little but are spacer/adapters that bad for your car? I heard if it's more than 2-3 inches it puts too much stress on your wheel bearings. Is that true?
Google "H&R springs" website, then find a vendor close to you... I got mine off ebay USA....
Thanks for the info.... I've sent a few emails..
