-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   3.2 rebuild underway.... (http://forums.pelicanparts.com/showthread.php?t=513402)
DUK 11-27-2009 03:19 PM
Had a fun day in the garage. Now to clean up the ports and recut the seats.
http://forums.pelicanparts.com/uploa...1259367390.jpg
http://forums.pelicanparts.com/uploa...1259367446.jpg
http://forums.pelicanparts.com/uploa...1259367481.jpg
500_19B 11-28-2009 03:05 AM
Looks spotless! How did you clean things so far? It looks like you have put in new valve guides already...
What jobs are you able to do in your garage and what (if any) are you taking to a machine shop?
Thanks for the pictures, very nice!
DUK 11-28-2009 07:33 AM
Cleaning was just solvent tank and then glass bead for the heads. The guides are the old original ones and measure out good. I've got access to a serdi valve and seat machine and will recut the seats there after cleaning up the ports. Then I'm getting the p&c's measured and if good honed using a silicon exposure process.
TT Oversteer 11-28-2009 10:36 AM
You have the heads removed, disassembled and cleaned and you're not going to replace the guides? These motors are known for premature wear of valve guides. What's the point here?
DUK 11-28-2009 11:36 AM
Is there a reason to replace them if they are not worn? I figure why take a chance on a new one being that the existing ones are proven.
Scott R 11-28-2009 03:54 PM
Oh man, replace them. My PO did an "economic" top end and didn't do them, but replaced the valves. They didn't last long. And this was a 3.0L, I would be much more concerned on a 3.2.
DUK 11-28-2009 04:35 PM
Well here's some of the work from today...
http://forums.pelicanparts.com/uploa...1259458423.jpg
http://forums.pelicanparts.com/uploa...1259458458.jpg
jimbauman 11-28-2009 04:43 PM
One reason to replace valve guides is that the old guides WILL wear out sooner than later, and newer guides are made from more resilient material .... they'll last forever.....so they say.... This is an older thread from Rennlist ... pretty interesting...
http://forums.rennlist.com/rennforums/993-forum/91905-obd-ii-cel-carbon-buildup-issues-long.html
JB
PS: nice, clean uncluttered shop. I like!
DUK 11-28-2009 05:10 PM
Thanx for the info Jim. I didn't realize porsche was using some inferior materials for the guides. Does anyone know what it is? What are the good ones to get?
jimbauman 11-28-2009 05:15 PM
Oh I wouldn't say that Porsche used inferior materials. It's just that advances in metallurgy and manufacturing techniques result in BETTER parts than were available 25 years ago.....
JB
DUK 11-28-2009 05:17 PM
Gotcha, Thanx.
88-diamondblue 11-28-2009 05:59 PM
You will be doing this again sooner rather than later if you don't do it now. The 84-89 Carrera's are well known for valve guides going well before 100,000 miles. Mine were shot at 88,000. Per Steve Weiner that phosphorus bronze is what they are made of except they are harder than the Porsche valve stems. Are you replacing your exhaust side cylinder studs with steel? BTW the heads look great.
WIL84911 11-29-2009 05:54 AM
My valve guides had to be replaced 600 miles after an engine rebuild. I now suspect they reused the old ones.
DUK 12-06-2009 08:15 AM
Ok guys what guides and valves are the ones to get?
DUK 02-17-2010 02:17 PM
Pistons back from coaters and intake being honed and lightened...
http://forums.pelicanparts.com/uploa...1266448585.jpg
http://forums.pelicanparts.com/uploa...1266448626.jpg
I should see the cams later this week and the valves anyday now.
DUK 02-19-2010 05:10 PM
Honed the intake and removed some of the unneeded stuff. No more useless mounts and vacuum ports....
http://forums.pelicanparts.com/uploa...1266631737.jpg
http://forums.pelicanparts.com/uploa...1266631788.jpg
http://forums.pelicanparts.com/uploa...1266631833.jpg
DUK 02-27-2010 02:06 PM
Rods: Triple checked both ends, installed ARP bolts, shot peened, glass beaded, and weight balanced. I was extremely surprised how good everything measured and weighed. Now to get my bearings back from Calico and start assembling.
http://forums.pelicanparts.com/uploa...1267311947.jpg
rnln 02-28-2010 12:07 AM
Since you are there, why not polich the intake. Will be a little lighter too :Dhttp://forums.pelicanparts.com/uploa...1267348047.jpg
DUK 03-07-2010 04:30 PM
No, Duk don't do polished. Too much work. :)
Here's the weekly update... Rod bearings back from calico and rods installed, along with arp head studs and crank seals.
http://forums.pelicanparts.com/uploa...1268011073.jpg
http://forums.pelicanparts.com/uploa...1268011789.jpg
DUK 03-27-2010 06:26 PM
Progress report....
http://forums.pelicanparts.com/uploa...1269743088.jpg
http://forums.pelicanparts.com/uploa...1269743124.jpg
