http://forums.pelicanparts.com/uploa...1566668727.jpg
http://forums.pelicanparts.com/uploa...1566668727.jpg Sharp edges of the dome smoothed-out. Some say this results in additional horses...? http://forums.pelicanparts.com/uploa...1566671843.jpg Beautiful work by Mark Motshagen - a hard man to track down. http://forums.pelicanparts.com/uploa...1566672226.jpg http://forums.pelicanparts.com/uploa...1566672226.jpg http://forums.pelicanparts.com/uploa...1566672974.jpg ... and test fitting the custom exhaust by Hoover. http://forums.pelicanparts.com/uploa...1566673358.jpg |
What headers are you using? Can't wait to hear what that exhaust sounds like.
WOW, love that muffler
Heard them on several NorCal cars at the Treffen this year and had to get one for myself. They do sound incredible!
1 5/8" headers http://forums.pelicanparts.com/uploa...1566684592.jpg that match the exhaust ports http://forums.pelicanparts.com/uploa...1566684678.jpg |
Dressing up the top-end. Trying to get one of these fancy things to fit...
http://forums.pelicanparts.com/uploa...1566696611.jpg The issue with these is that they don't have the ducting to direct air to the oil cooler. We all know how important it is to keep the temps down as much as possible, so I was able to locate one of these - all the way over in Montreal Canada! Started ugly, but with a little massaging, she's good as new. http://forums.pelicanparts.com/uploa...1566696804.JPG http://forums.pelicanparts.com/uploa...1566696804.JPG |
Very nice work Brian. Your engine is so gorgeous I would like to borrow it for an hour in private. Ok, maybe only 5 minutes.
Wow, beautiful as always with your work. Can't wait to hear that exhaust.
Done fiddling with the shroud and the motor is pretty much done. Now I have to make the tough decision of choosing an ECU and figuring out the wiring harness - Motronic, AEM, blah, blah, blah...so many choices. Before the new motor goes in though, I will need to rip out the old, single steel fuel line through the tunnel and replace it with twin Polyamide lines, new high-pressure pump, etc. More to come.
http://forums.pelicanparts.com/uploa...1568070913.jpg http://forums.pelicanparts.com/uploa...1568070913.jpg http://forums.pelicanparts.com/uploa...1568070913.jpg |
He told me that story about Barry White - epic! Can't wait to hear it sing.
What was your HP increase on the dyno? |
Hi Brian
I recently had the pleasure of meeting the fellow to whom you sold your ducktail. I really like the look of it on his '84. He recommended I have a look at your thread as I am presently engaged in my own attempt at a restoration project - pretty mild compared to your project. The work you have done is very impressive & your detailed account of your progress makes for an interesting & informative read. You have illustrated how one with the necessary skills, patience, & dedication, can achieve the outstanding results you have attained. Thanks for taking the time to chronicle your efforts on the "Waterlogged Rust Bucket" "Ya done good" Cheers JB Also looking forward to having a beer or two with our fellow enthusiast. |
Blee, did you use fiberglass for the heat block off plates? If so how well did they fit?
Thanks David |
Cheers back to you JB! You're in good company, even the factory agrees with your aesthetic approval of the duck tail on later cars - "R." Fortunately, there are many vendors for you to choose from so they are readily available, go for it - it'll look cool on a 997.
I too look forward to a day when we can meet up with our brothers from across the border. Someone needs to bring back the PNW/Canada Treffen. David - I did go with the FG block offs. As you would expect, they don't fit as well as the steel ones and require some fiddling to get them to work. There are some bigger gaps than I would like, but oh well. It's that much lighter, right?! I justify it by telling myself that it'll allow for heat to escape. ;) |
Sourcing the right sized ignition coils was fun, but finally found some that are the right length and fit snugly in the valve cover openings. Turns out '04 Audi Quattro 2.7L coils will work on our motors if you use 5/8" plugs. Different manufacturers out there but decided to go with Denso units with NGK plugs. Added the RSR brackets for backup so they are not going anywhere.
At this stage, the motor seems to have an insatiable appetite and is swallowing parts by the dozen! Next up is the daunting task of creating a wire loom to connect all the new electronics. http://forums.pelicanparts.com/uploa...1571069274.jpg http://forums.pelicanparts.com/uploa...1571070439.jpg http://forums.pelicanparts.com/uploa...1571071377.jpg |
That's a great looking Engine!! Can't wait to see it when completed.
What plugs did you use?
Chose standard NGK R's - BKR7ES-11. (5/8" vs. 13/16")
I realize there are lots of discussions about gaps being smaller for higher HP motors & wider for bigger spark, etc., and the fancy Platinum, Iridium, kryptonite, mumbo-jumbo... These plugs are the same in every aspect as BCPR7ES - Nickel plated copper, ribbed, warranty, heat range, price, and size, except the gap - 9mm vs. 1.1mm on the -11. Why NGK didn't use a consistent part no. like BKR7ES-9 for the 9mm gap? Go figure. |
| All times are GMT -8. The time now is 03:18 PM. |
