87 Carerra, 3.2 liter en
Cabriolet Help
I have a 87 911 and I need the PDF version of the Cabriolet system.
My top stopped working and I am trying to repair it. the Bentley Service manual that I have does not go into depth on Cabriolet top repairs in terms of trouble shooting and electrical reparir, etc. It is my understanding that there is a PDF repair manual of the Cabriolet system. Does anyone have it. Last edited by Srwilliams; 01-30-2010 at 07:42 PM.. |
i would not mind a copy of that myself, nothing wrong with mine, but you never know.
What is your problem?
cheers hg 1988 911 Cabrio |
Where are you located? I think I have it in the Porsche pdf manual....
There is a video on disk for adjustment and operation.
Kuel,
Where can I get this video? My top works but will not latch using the motors. It will unlatch and go down but not latch when closing. I just had a new top installed and that is when i sterted having this problem. I am sure it is just an adjustment. Please send me the link. Thanks, Jeff |
muck-raker
I would also appreciate any information on an existing disc, manual or .pdf file in particular.
Thanks for your help...anybody???
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Happiest when Tinkering
+1 I am intrested in all this info also thanks
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
My left locking motor is not in sync as well. Any info I could use as well!
gduke2010
It could be an adjustment problem. There is also a relay under the passenger side floor and microswitches which are easy to adjust under the panels on each side in the back seat where the top transmission mechanisum is located. An easy fix would be replacing the microswitches. If the top needs adjusting be careful. My left side top bow broke, punturing the top. Theres also issues with the motors which was part of my problem. An old and tired motor was drawing too much power, which caused the relay to fail.
When I picked up my 87 cab my back 'bow' aluminum horizontal support was broken. Took off the top, removed the bow and TIG welded it.
The cause for the break was because the LH and RH side actuators were out of sync. The out of sync was because one of the actuator boxes was loose (loose bolts). After putting a new top on myself (oiy, oy, ug), I spent weeks learning how it all works; imagine an orchestra or clock movement. That's when I came across Peter Sandholdt. I think Pete is here on Pelican so you can look up a thread and contact him directly with regarding to the mystical cab tops and information on 'how to'. |
Srwilliams - did you ever get this resolved? I ask because I just joined the membership of tops that like to go down, but not so keen on coming back up again.
In particular, my lid came all the way up but would not latch. And once in the up position, possibly because the micro-switches were not making contact with the window frame, the roof would not go down again either. Sigh.
C.H. Boost Addiction - honestly, I have it under control 1989 911 Turbo Cabriolet Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace |
