AutoBahned
It's an '85 targa with auto heat... |
Sounds like no heat is making it into the heater duct on the left side. First thing I'd check is if the hose on that side between the heat exchanger and flapper valve is missing or disconnected. A car with auto heat uses one cable that is folded in half and has a loop twisted into the end that attaches to the lever operated by the servo. Because of this, it can only pull on both flapper valves together. It's not unusual to have the flapper valves stick in one position, but the fact that there is only one cable half working indicates that the end of the cable on the left side might be broken, or loose in the little clamp.
It ought to be pretty obvious if you can crawl under the car and have a look. In the meantime, move the red lever on the dash all the way to the left, the middle lever all the way to the right and the two upper levers all the way to the left. Crank the heat on but try to keep the footwell blowers at the low speed. So, maybe 1-3 on the dial. JR Last edited by javadog; 12-12-2013 at 12:16 PM.. |
Yep, good call. The hose was disconnected...
