Heating problems
OK,when I pull my heating levers up I get heat, but my fan control switch does not select from 0,1,2,3 anymore it just stays on one speed and I don't even no what speed it's on. Could it be the switch?
A man who dares to waste one hour of time has not discovered the value of life.......
Much Respect
Old 03-21-2010, 10:42 PM
dshepp806's Avatar
Fuse...possibly.
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-22-2010, 03:00 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Do you have a Bentley?
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-22-2010, 08:09 AM
No, I do not have a Bentley,I think I should probably get one.
Much Respect
Old 03-22-2010, 06:36 PM
aj88cab's Avatar
Does the engine blower fan (in engine compartment) come on when you pull up the heater levers? Are you sure the footwell blowers are running? If they are running are they loud, possibly indicating the high speed (position 3). Is it possible the heat you are getting is just from the engine cooling fan pushing air through the heat exchangers? These answers may help us islolate your problem...maybe
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 03-22-2010, 08:07 PM
1)yes the fan in the engine compartment does come on when I pull up the levers
2)where are the foot well blowers?
3) the heat that is coming out is very good,not to loud, I mean it sounds like a fan.
Much Respect
Old 03-22-2010, 09:25 PM
aj88cab's Avatar
The footwell blowers are behind the right and left footwell panels. If you get your head down near them you can clearly hear them running. Do the footwell blowers go off if you put the rotary switch on position 3? Make sure the fresh air fan is off (dash controls) so you don't confuse the sound.
If the footwell blowers go off on position 3 check the round relay on the front trunk relay panel (position 1, closest to the windshield). Switch the relay with another relay to check. Also check fuse #2 (counting from the rear of the front trunk fuse panel).
If the footwell blowers stay at the same speed on position 3 it might be the rotary switch, but it could be the above round relay with the contacts fused "on". The footwell blowers would be running at the high speed in this case. Switch the relay as described above to check.
Old 03-22-2010, 09:38 PM
O.K, if I select the switch, there is no change, so I am assuming that it is the switch that is failed.
Much Respect
Old 03-22-2010, 09:45 PM
aj88cab's Avatar
I edited my post above after I thought about it. It might still be the round relay. Switch the relay and see what happens.
Old 03-22-2010, 09:47 PM
I will try it, thanks Bro I will let you know.
Much Respect
Old 03-22-2010, 09:53 PM
