motorcop's Avatar
Cool 3.2 air box mods?
Just finished installing Steve Wongs chip and M&K cat bypass. The car screams! Best bang for the buck IMO. While speaking with Steve he said that opening up the restrictive stock air box could be worth up to an extra four horses along with the "sound" at 3/4 to full throttle of the extra air getting to the motor. I checked the search feature but struck out for info. Anyone modify their 3.2 box? Pros? Cons? Photos? Thanks guys!
Old 04-27-2010, 06:13 AM
Friend of Warren
Did he really say that? All research out there indicates that the exhaust is the restriction in the system. The intake, in stock configuration, can flow more air than the 3.2 engine can use. If you want to hear it make cool sounds either take the snorkel off or cut some holes in the face of the airbox.
Kurt V
Old 04-27-2010, 06:30 AM
You should be able to find pics where folks have drilled holes or otherwise cut up the airbox cover. I think Fabspeed has a cut out cover. Louder sound sure but power adds are debatable. I did the SW chip and cat replacement but left the intake alone. Ken
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 04-27-2010, 07:27 AM
Throw it on the ground!
Here are some ideas for you. I have done the first one (pretty common mod).
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 04-27-2010, 07:33 AM
Zeke's Avatar
None of those ideas are good if you wash the car or leave it out in the rain.
When you look at the size of the butterfly, you realize the horn supplies all the air that is needed. The restriction is the filter itself in spite of it's large size relative to the butterfly. You could go with a K & N which has not been proven to be of any great advantage, or just keep a fresh and clean stock element in there.
I guess the holes at the bottom don't hurt.
Old 04-27-2010, 08:27 AM
Send a message via AIM to NoLift911
Easiest way to make the mod (vs. turning it into swiss cheese) is to put the box on a table saw and cut it down so it is just clips and the frame to hold in the filter - takes about 5 minuets and comes out very clean.
What this will get you is an un-holy howl when you are WOT around 4-5k rpms which sounds like someone is sucking all of the air out of your ears...
I have this mod in my 3.2 Carrera, along with Steve's chip, cat-bypass and a RUF sport muffler which really wakes up the car in all areas.
One step further is to take a ton of weight out of your car - all of this really gives you some biscuits and gravy for a stellar power to weight ratio = fun.
I helped a buddy install a 3.6 into his 86 Carrera - his car has all of the accoutrement's that Porsche offered from the factory, mine is stripped. There is not much difference in the two cars in terms of power. I took over 500lbs out of my car (512 and counting) He is now stripping his down and I am sure he will realize the beneifts of the 3.6 swap.
Jeff
Old 04-27-2010, 08:51 AM
Northern Motorhead
wildcat077's Avatar
I went with the Fabspeed cover and K&N filter along with the SW chip and other exaust replacements and i have to admit that when the chip kicks in between 5000 to 6500 rpm's the sound is awesome ...
Sounds a whole lot different than when it had the stock airbox... horsepower gains ???
Who cares,it sounds too good
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 04-27-2010, 09:28 AM
m110's Avatar
It should be noted that the factory itself provided a "motorsound package" for the 993 which included a drilled-out intake. I like the sound and only drilled the front most portion so water doesn't get in.
1988 Carrera Coupe
Old 04-27-2010, 01:19 PM
Make Bruins Great Again
Por_sha911's Avatar
This one is my doing:
Sounds better (but probably not as good as taking the entire face off) and since the car has A/C and you barely notice the holes when the cover is on. I've driven in rain (and been caught in major downpours) and have had no problem with ingesting water.
Joe
Old 04-27-2010, 02:28 PM
Schwarzeritter's Avatar
Location: PaloAlto Calif, IndianWells PalmDesert, Japan
Interesting, I haven't looked up close at a Sound Package. Especially since I am not sure
how many cars came equipped with it, and to find out for me is sort of trivial haha.
But in short I think the Swiss Cheese method is better, although it sort of renders the " Intake Velocity Tube " useless.
However what would be very interesting, would be to set up a test bench and test each set up, and for kicks the 993 sound package and see which flowed the best. Although remember flow is good, but you still need velocity too. Although a extensive and well developed rig would be needed. Good times!
On filters, I would rather have a filter that filtrates better then flows, so long as it did not constrict air flow below that of the original filter unit. =D
Taze em..TAZE EM ALL!!
A man that builds a thousend bridges is a bridge builder, but a man that sucks one ( blank ) is a ( blank ) sucker.
It looks like the 4th of July from my rear view, how about from your view?
Old 04-27-2010, 03:11 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
I swiss cheesed my cover as well. sounds a little better but didn't make much difference. it is true that all gains come from the exhaust. i went to a cat by pass and it made a big difference, then i went to SSI's and an M&K 2 in 1 out. huge difference. but apparently, even the SSI's are a bit restrictive for the 3.2... so there is the possibility for more!
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 04-27-2010, 03:15 PM
motorcop's Avatar
Thanks Guys......keep em coming....Im listening!!
Old 04-27-2010, 04:02 PM
Has anyone done this intake? A well respected tuner recommended this particular product, slightly modified.
MSDS - Air Intake Systems
1979 911SC Euro Tub/1982 Euro 3 Liter PCA E Class Race Car
1985 911 Carrera Coupe-Grand Prix White/Red
Old 11-26-2015, 07:25 AM
Mostly just for looks and yet does as much good as Swiss cheesing your wallet, performance wise. Do a search, the data is in.
Old 11-26-2015, 10:48 AM
Lots of butt dyno stories - where are actual dyno sheets with/without air box holes?
IMHO - leave the $%*& thing alone and drive the car.
Sold: 1989 3.2 coupe, 112k miles
Old 11-26-2015, 11:36 AM
Bird911's Avatar
I did replace the airbox with a K&N cone filter when I had my 3.2. I can't say I felt a difference. But, who can really feel a 1% difference in power. (If I recall they claim a 2-3 HP increase. This need to be proven.)
What I mostly liked with the cone is that it cleaned and opened the engine bay nicely.
Hugo
Old 11-26-2015, 12:04 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Keep the OEM air box and buy an aftermarket pre-cut cover. Just in case you need to go back to OEM to pass smog inspection. Some of us have failed because inspector determined it was modified.
Finding an OEM cover is difficult.
In writing this I have cut mine too. After watching SW's dyno test of it stock vs cut out air box. I was convinced, out came the Dremil
No issues with rain or washing, BTW. I wash my engine bay allot, OCD like that. ( I went from Coned Filter due to excessive dirt intake, yes properly lubed )
'85 Carrera Targa
PCA/POC
Old 11-26-2015, 12:46 PM
Yes, this seemed to me like a good system. It uses a molded intake adapter, with a smooth transition between the round filter and the rectangular AFM. The filter looks like high quality, maybe S & B? Anyway a nice product.
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 11-26-2015, 12:49 PM
Do you really think that Porsche missed that simple trick? Thank goodness there are some of us who know better than the factory.
Old 11-26-2015, 02:04 PM
My goodness. Do you think the only factor for the engineers was performance? 30 years ago?! Maybe they had to compromise for the sake of emissions. Who knows.
They were very smart, but they did not have the same design parameters.
Really, is this news to you!!??
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 11-26-2015, 02:42 PM
