3.2 rebuild underway....
Had a fun day in the garage. Now to clean up the ports and recut the seats.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
Looks spotless! How did you clean things so far? It looks like you have put in new valve guides already...
What jobs are you able to do in your garage and what (if any) are you taking to a machine shop? Thanks for the pictures, very nice! |
Cleaning was just solvent tank and then glass bead for the heads. The guides are the old original ones and measure out good. I've got access to a serdi valve and seat machine and will recut the seats there after cleaning up the ports. Then I'm getting the p&c's measured and if good honed using a silicon exposure process.
You have the heads removed, disassembled and cleaned and you're not going to replace the guides? These motors are known for premature wear of valve guides. What's the point here?
Is there a reason to replace them if they are not worn? I figure why take a chance on a new one being that the existing ones are proven.
Oh man, replace them. My PO did an "economic" top end and didn't do them, but replaced the valves. They didn't last long. And this was a 3.0L, I would be much more concerned on a 3.2.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Well here's some of the work from today...
I'm here to cause trouble
One reason to replace valve guides is that the old guides WILL wear out sooner than later, and newer guides are made from more resilient material .... they'll last forever.....so they say.... This is an older thread from Rennlist ... pretty interesting...
http://forums.rennlist.com/rennforums/993-forum/91905-obd-ii-cel-carbon-buildup-issues-long.html JB PS: nice, clean uncluttered shop. I like!
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) Last edited by jimbauman; 11-28-2009 at 06:00 PM.. |
Thanx for the info Jim. I didn't realize porsche was using some inferior materials for the guides. Does anyone know what it is? What are the good ones to get?
Oh I wouldn't say that Porsche used inferior materials. It's just that advances in metallurgy and manufacturing techniques result in BETTER parts than were available 25 years ago.....
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) |
Gotcha, Thanx.
3.4 Bigger is better
You will be doing this again sooner rather than later if you don't do it now. The 84-89 Carrera's are well known for valve guides going well before 100,000 miles. Mine were shot at 88,000. Per Steve Weiner that phosphorus bronze is what they are made of except they are harder than the Porsche valve stems. Are you replacing your exhaust side cylinder studs with steel? BTW the heads look great.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
wannabee wannabee
My valve guides had to be replaced 600 miles after an engine rebuild. I now suspect they reused the old ones.
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) |
Ok guys what guides and valves are the ones to get?
Pistons back from coaters and intake being honed and lightened...
![]() ![]() I should see the cams later this week and the valves anyday now.
Honed the intake and removed some of the unneeded stuff. No more useless mounts and vacuum ports....
Rods: Triple checked both ends, installed ARP bolts, shot peened, glass beaded, and weight balanced. I was extremely surprised how good everything measured and weighed. Now to get my bearings back from Calico and start assembling.
Since you are there, why not polich the intake. Will be a little lighter too
Fat butt 911, 1987 |
No, Duk don't do polished. Too much work.
![]() Here's the weekly update... Rod bearings back from calico and rods installed, along with arp head studs and crank seals. ![]()
Progress report....
