Max-Moritz Conversion
I am in the process of rebuild on my '80 SC - I have found that the piston/cylinder combination is a 98 mm bore - referred to as the "short stroke 3.2L conversion".
All is going well except I am having difficulty finding a source for the piston rings - the piston marking is "Mahle 98P11".
Anyone know where I can find rings for these pistons?
Old 07-06-2010, 09:40 AM
I would rather be driving
jpnovak's Avatar
You will need to measure the ring lands and figure out which ring sizes you need. I built my 3.2SS with 98mm Mahle and had to get custom rings made from Total Seal. However, I think my top ring land had been recut from 1.5 to 1.75mm.
Old 07-06-2010, 09:43 AM
My ring land sizes are 3.0 mm thick on the oil rings, 1.2 mm on the compression rings.
Is custom machining the only solution?
Old 07-06-2010, 09:47 AM
m110's Avatar
Call engine builder supply, they will know
EBS Racing - Porsche Parts Exclusively
1988 Carrera Coupe
Old 07-06-2010, 10:22 AM
Carrerax's Avatar
I just bought a set of Max Moritz rings from Rennsport Systems dot com. And no, pelican didnt have them.
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 07-06-2010, 02:21 PM
Thanks - I am contacting Rennsport for their feedback on availability.
Do you recall the thickness of the compression ring set?
Old 07-07-2010, 07:13 AM
Carrerax's Avatar
Sorry, I dont remember. I did measure the ring lands and they were standard. Steve hooked me up.
Old 07-07-2010, 07:17 AM
EBS had the exact rings I needed IN STOCK.
Thanks all the help and input.
Old 07-07-2010, 08:56 AM
