shifter ?'s
Hey there,
I am wondering if there is an easy way to get to my shift rod (prob the wrong name, but the stick that the knob is attached to) out so I can change shift knobs and spruce it up with a fresh coat of black paint. What's a factory close out of a can black for this?
Also, I've checked the archives and am having one hell of a time getting my knob removed... It's a '77 so I've got the 915 tranny. I just want to install my Imagine Auto knob I got for x-mas.
Thanks for you help,
Pete
Peter Knell
'77 911S
'59 VW Panel --Show Winner FOR SALE
Old 01-11-2002, 12:52 PM
The shifter mechanism has to come apart to remove what you call the "shift rod"; see:
http://www.pelicanparts.com/techarticles/911_short_shift_tindel/911_short_shift_kit_install.htm
The "shift rod" is held by the shifter pivot pin and the bottom ball end is pressed into the pivot ball cup. A crush sleeve holds on the knob; the knob may be knocked off the "shift rod" with the technique described in the above tech article.
Jim
Old 01-11-2002, 02:56 PM
