What do you use to catch your oil?
Sorry for such a newbie question....
![]() I have a new-to-me 1985 Targa and I'm preparing to do an oil change. I have read numerous posts about the process, etc. and each one says something to the tune of "be careful to make sure you have something big enough to hold all the oil or you'll have a huge mess". I looked for an item in our host's catalog, but didn't see anything. I'm trying to keep the oil change process simple and get the right tools the first time. What do you use? Thanks in advance. Lawrence |
A five gallon bucket works for me. Either Homer or Lowes.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
I personally use two oil pans. One of the large ones for the oil tank and a small one for the case drain. The large one will need to be able to handle 8 quarts or so and the small one around 3 quarts. Every local auto parts place seems to carry both sizes...
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Ditto. They're tall so they help contain the splashing.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
Caveman Hammer Mechanic
Hey,
I use baby sea otters and wipe up the over spill with ducklings, mallards are the most absorbent. eric
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
oil pan
You can find a low oil catch pan that will hold 15 quarts at NAPA.
Just hollow out the center hole because the hot oil will flow faster than the hole will drain i9nto the body of the pan |
i bought one of those big drain pans that has a screw cap in the middle and a spout with a cap on one end. i think advance sells them although the ones they sell nw dont look to be as good as the one i have. mine looks like this, except with everything, they arent as good as they use to be. the drain hole on mine is bigger and has a screw cap. mine must be at least 15 years old, worth every penny.
Northern Motorhead
If you have a pool you can use an empty chlorine container...
That's what i use for the oil tank and i use a regular black oil drain pan for the drain plug on the engine. I jack up the right rear of the car and remove the wheel then just slide the container under the oil tank drain plug ! Real simple and cheap ! Cheers! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
The large 5 gallon yellow (sometimes green) open top plastic pan used for draining the coolant from a radiator, search blitz 11845 on the net. If you are changing the oil hot get some rubber insulated chemical gloves. Once drained you will need another container to transport the used oil for reclaim.
You can't use a bucket unless you lift the car off the ground.
Large low container is much easier since there's no reason to lift the car; access is fine. Last edited by tcar; 11-09-2010 at 09:34 AM.. |
Senior Advisor
True, use a drill and a 1/2" bit and drill several holes around the single hole in the middle of the drain hole. First time you do this (drain oil) it will get your attention fast! Get a 15 qt. size and it can fit under the car without jacking.
08 Cayenne Turbo |
Not to mention that the oil drains out faster than that little hole in the center allows it to drain into the container. A LOT faster. Ask me how I know...
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
![]() Brian
'82 SC Targa '83 SC Cabriolet |
Model Citizen
a smaller drain pan under the crankcase and the oil is out in two shakes of a lambs tail. (no need to lift the car!)
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
My oil collection pan looks like this:
The opening has a screen to catch you drain plug and is about 7" in diameter. I can slip it under my car with minimal jacking to allow access to the sump plug. It looks kinda like a 16 quart jerry can. Once it it filled, there is a port at the top to drain it into your container. Very slick.
SC |
oh, i can change my oil without having to jack the rear up to get a 5 gallon jug under it.
Paper Member
I just use a plastic dish pan, like 11 or 12 quart. I dump it into a 5 gallon gas can reserved for used oil, and take that to AutoZone when it's full.
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
