SLR
Door handel
I Brooke the trigger on the driver side. So now I have second hand
one but the lock part is not the same. my old lock fits in ok but and works but when I fited it it would not work on locking. So what I m going to do is use the old handel and use the new triger, but I can't get the bolt thing out of the new handel. I have tryed vice grips but it will not undo. any help would be handy. Thanks Steve. |
1980SCMan
These plastic handles break. You can buy the right handle to replace it from our host for about $25. Mine broke. I solved the problem with a pull strap. I'll soon replace the stock panels with RS panels which have a proper strap to pull. If you want stock, buy the correct part.
SLR
Sorry it is the outside handle.
Have you pics?
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
I replaced the same door handle trigger and don't remember any difficulty just popping the trigger out.
A picture would help.
Jeremy 85 Targa |
Not sure if this PP link will work but it sure helped me recently when I fixed mine or just search door trigger and you will find lots of help
http://forums.pelicanparts.com/porsche-911-technical-forum/347343-door-handle-assembly.html Terry
79 SC Minerva Blue ROW Non Sunroof Crank Window Coupe 3.0 SSIs, Backdated Heat COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires |
more entertainment
http://forums.pelicanparts.com/porsche-911-technical-forum/439019-911-door-handle-triggers.html
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
just use the trigger from the replacement handle in your old handle.
