Ungo Box Mystery
I have a 1977 911S that I recently inherited. Searching through the documents that came with it, I found that my dad purchased the car used in 1984, and was the second owner. It came to me with an Ungo Box in the glove compartment that I've done my best to remove. I wasn't using it and posts in this forum speak of electrical gremlins and stranded Porsche's which convinced to try to fix something that wasn't really broken. The fact that the Ungo appears to have been professionally installed (good connectors, wire looms, grommets in the firewall), and using these forums to estimate its age, I'd say it was installed by the Porsche dealership that originally sold the car. Removal went fine except for one stupid wire. In the Ungo harness, this wire is purple and attaches to a red Porsche wire behind the fuse panel on the driver's side. That red wire disappears into a wire loom along with about a million other wires. It seems like this wire was originally attached to a fuse, but which one? Further hampering this effort is the fact that the Ungo itself has no model number! So here's what I'm really looking for:
1) an installation guide/manual/wiring diagram, or 2) in lieu of 1, an ID on the model number so I can search effectively for those documents, or 3) an ID on the red wire behind the fuse panel, and to which fuse it attaches. I've attached photos of the offending unit, which by the way measures 6"x5"x1.6". Any help would be sincerely appreciated. ![]() ![]()
there are wiring diagrams free on the host's website. that may be the last electronic device made in the US.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Does it tick??
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
Thanks schumicat, but I was hoping to find the Ungo wiring diagram. I have the Porsche diagram for my car, and while I'm terrible at reading these things, I can't narrow down that red wire.
As for the country of origin of this item, I hadn't even noticed it was made here in the US. Kinda makes me feel guilty for removing it. |
Fishrule, I'm sorry I was just kidding about the ticking.. I would try a web search for the manufacturer, or possibly Ungo itself..
Neel, my family has always said that I'm gulible. Guess this proves it.
![]() As for the web searches, I've done them. And then some. Ungo seems to have gone out of business, but not before producing enough products to make searching without a model number a ridiculous exercise. There are just too many choices, and very few photos that would help me with a positive identification. |
What are you going to do with the box after you remove it?
UNGO Box is out of business. I think Clarion acquired them some time ago. I think the model TL-1250 and TL-1000 where popular VW and Porsche boxes in the day - might start there. You can download PDF manuals for these.
Look at this page Book Of UNGO It is a newer BMW model but note that the schematic to the alarm computer has several same colored leads as yours which may help you trace the wires. Also found a box like yours on Craigslist. Contact the seller as he has a manual included and it's only $19.00 for the whole thing. http://newjersey.craigslist.org/pts/2145323442.html Hopes this helps some. Last edited by bfunke; 01-17-2011 at 08:03 PM.. |
Paradigm Short Shifter
Hehe. Yours looks newer than the one that was in my car. The box itself in my 81 targa jus had an on off switch. And there's this extra toggle switch that looks like an 81 fader switch up under the dash that doesn't do anything anymore. Heh, the PO had some stereo work done and did get an amp installed, but he wired it so that the aerial for the radio was completely controlled by the fader switch. Hahahha!!! Now people Sony know if I'm listening to a cd, or if I had a psychotic break and am talking to one of myselves in my car while driving down the road with that aerial down. And seriously, I really do like being able to put the antenna down when I don't need it. Just flip a switch when I switch over to fm.
All joking aside. Apparently I got lucky with how my ungo box seemed to just not work anymore. I think it was disabled, although there is a massive rat's nest of wiring for it just on the other side of the firewall, under the carpet on the passenger side just on the other side of the grommet that let the wiring in. I want to remove it, but I'm scared that I'll unbreak it and then only be able to ungo. Michael |
Arizona 911, I have no idea. I don't even know if it works. Perhaps someone will want it for a period restoration. Interested?
bfunke, thanks for your time. I will look up those models immediately. The BMW install that you linked to has LED warning lights, motion sensors, etc. My old Ungo predates all of that stuff, unfortunately. And I will contact that Craig's List seller. Although his item is newer than mine, it might be worth the $19 to find out how similar. UrQuattro, Like you, I should've probably left well enough alone, but I'm a tinkerer and I wanted my glove box back! Most of all, I didn't want to get left on the side of the road with a non-functioning car. Now, at least, my non-functioning car is in my garage. |
Yes, I may be interested. When you decide what you are going to do, let me know. Thanks
that's a candidate for the round file. antique stuff. toss it and install something up to date if at all.
Been here a while
you can be pretty confident the red porsche wire is providing power, and with a simple 12volt test light (available at any car part store, it's a probe on one end and an alligator clip on the other, you ground the clip, the probe tells you when the wire you are touching is live)
so, test--1--key off is there power? test 2, key on, is there power? the alarm wants power when the key is off to energize the alarm system and potentially signal the siren really, the ONLY wire you care about is the starter or running disabler, often there will be a circuit on the alarm to break the yellow wire, so the starter motor cannot turn, otherwise, it could interrupt the ignition system. so, it seems you could probably just cut the red wire and possibly just cap it. as background, I've removed dozens of alarm systems over the years, and back 15 years ago, I installed even more....I paid my way thru high school and college doing high end car stereo and security system installs.....but it's been a very long time since I was around an ungo box. Lewis
looking for 1972 911t motor XR584, S/N 6121622 |
Wow, that should be in a museum! Is that from around 1977?
I remember you had like 10 seconds to enter the car dial in the combo and hit the button. I think Clifford had one like it too as seen in the first episode of Magnum PI ! Best to leave it out of your car all together.
Work to Live, don't live to work... |
Happiest when Tinkering
I had one of those in my car and it was state of the art in 1982 there was nothing that could touch it saved my car from being stolen often in Hawaii the worst I got out of it was a broken wing window. I think the purple wire was passive arming wire when you shut the car off it would sense power loss and arm the system. Cut the purple wire close to the red wire and shrink tube it unless the red wire is not going to anything then trace it back to it source and remove it but I think the red wire is a feed to something.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me Last edited by gsmith660; 01-18-2011 at 04:53 PM.. |
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
abit off center
put in code 7700 and see what happens.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Band.
+1 I think it's a safe bet that the purple UNGO wire to the red Porsche wire is switched 12V, and as mentioned you can find out pretty easily with a meter or a test light.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
