RETIRED
60-80 bucks you can get a decent Fluke on EvilBay.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Member 911 Anonymous
When I replaced my Mother's starter, the new one I purchased was defective.
AAA came out and tested my starting system i.e. battery, alternator and starter. Found out new starter was bad. Verified at Auto2one and replacd for a working one that they tested before I left the Store.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
RETIRED
Starter rebuilds are such a racket. Rebuilds with lifetime warranty, they don't cover R&R.
If you can tolerate no current (amp) readings....even the small, foldable pocket digital style at Radio Shack is good for $28.....I've checked these against Flukes and for all other read-outs....they both read the same. Electronics guts....doncha know. They either tend to read correctly or not at all.
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
I am planning on re-building my starter with an electrical pro ( most likely he will do and I will be the camera man) and posting a video soon.
Watching Vids on youtube and reading the Haynes manual seems easy enough, mostly cleaning, bearings and lube. Wonder where you can get new brushes and coils. McMaster Carr???
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 01-30-2011 at 01:28 PM.. |
Before the long wire is connected to the starter for this test, remove the coil wire from the distributor. In other words, unplug the coil wire...this is the spark plug wire in the middle of the top of the distributor that runs to the coil. If this is removed, the engine will not run.
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
The lower current ranges are useful for things like finding what's draining your battery when you're not driving the car, though. ![]() The only advantage of a good meter is that it is more likely to work when you want to use it - I replaced 3 $40 multimeters 2,3,4 years apart until buying a used Fluke 77 4 years ago. Which still works perfectly. The accuracy of even a cheap, uncalibrated meter isn't an issue for auto work - they're fine.
'77 S with '78 930 power and a few other things. Last edited by spuggy; 02-01-2011 at 09:18 AM.. Reason: Fat-fingered and posted too early... |
darshie
I had similar issues with my 930 had replacement starter motor installed new battery Cleaned all battery connections and ground strap to body connection My French mechanic reckons he has solved the problem and claims the heavy gauge cable from the positive terminal to the starter motor was not tightened on the positive terminal. He also cleaned up all of the connections at the left rear of the engine bay where 'starter relay' is? - I have only been driving it since this morning, so far so good - still carrying the spare battery and jumper cables just in case! My symptoms also went away with a charged battery or if the car sat overnight. With a full charged or new battery it seemed ok for a while I may still have to install a 'hot start relay kit' Not 100% convinced my problem has gone away and so will be watching your progress - good luck! Ben
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001 1984 Carrera 3.2 IROC RSR look |
