Hodgey's Avatar
Porsche Crest Changing to an Optima RedTop....
...but does my charging system know the difference between a lead acid and an AGM?
Is it a 'plug and play' affair or will I need to modify the circuitry?
Thanks for any help in advance.
Neil
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 02-15-2011, 04:07 AM
aualexa2's Avatar
I put one in my '87 911 and didn't have to change anything except making the battery mount.
Alex
‘73 914 1.7 Phoenix Red
'99 SPB #79
'16 Cayman GT4 GT silver
Gone: '87 911 Blk/blk sunroof coupe, '13 991S Dbm/ag non-sunroof coupe
Old 02-15-2011, 05:11 AM
JMatta's Avatar
I've had a Red Top in the '73 for the last eight years, without issue (still running strong). Turn the cutoff switch to "off" position when not running and the battery doesn't even need a boost come spring.
'73 911 Frank 'n Meanie
2002 Boxster S
PCA Instructor Circa '95
Old 02-15-2011, 05:19 AM
Recreational User
porschenut's Avatar
It's plug and play. Optima Red Top is probably the most discussed battery on this board, and a very popular choice.
edit: I've had one in my car for the last 6 years and it's still working like new.
Old 02-15-2011, 06:47 AM
arbita1's Avatar
I have it too. It's a great battery. It's always strong even after a long period of not being started. I'm on my second one. My body shop somehow killed my first one when he had the car for 6 months. (Actually that's the second time he did that to me. He killed the battery on my 944 when he had that as well).
AJ USA has a mount for it so you can use the factory installation bolts.
Matt.
83 911SC
85.5 944 NA - Sold
Old 02-15-2011, 07:01 AM
Jupiter 911
bklyn's Avatar
I also have an 87, just modify or change your mount and its ready to go!
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 02-15-2011, 07:51 AM
brads911sc's Avatar
Good Choice
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 02-15-2011, 07:53 AM
muck-raker
kidrock's Avatar
This is excellent advice when using this battery. The next best thing is to use a Battery Tender when the car is not in use.
My personal experience with this battery is that although it is smaller and lighter, it needs a bit more attention than a regular battery....especially in colder weather, or when the car sits for extended periods. YMMV
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 02-15-2011, 07:58 AM
Had one in my '73.5.
I laid on it's side in the left battery box. In lieu of the 2 small batteries that were stock.
THey don't have to be upright.
Always started the car... for years... all winters, too.
Old 02-16-2011, 03:32 PM
Hodgey's Avatar
Decision made fellows......thanks for the guidance. I have a query though insofar as why do you need to extend the ground cable? Can't you just turn the battery around so that the +tive pole is nearest the fuse holder/relay box?
...just askin'.......
Neil
Neil
Old 02-16-2011, 04:57 PM
Installed on it's side in the battery box in November of 1997
Started just the other day
Could 13 years be a record?
Old 02-16-2011, 05:01 PM
Hodgey's Avatar
I'm off to the Auto Zone right now!!!!!!!!!!
Neil
Old 02-16-2011, 05:04 PM
The orientation of the terminals for Optima for 911 fitment places the postive terminal near the backside of the car...on the battery side closest to the gas tank. The negative terminal is toward the front of the car, but also on the same side...toward the gas tank. The stock negative cable is too short. The new one has to be something like 9" to 14" long. See here-->
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-16-2011, 06:41 PM
This might be a better angle shot....
Wil Ferch
Old 02-16-2011, 06:52 PM
Hodgey's Avatar
Thanks Will.....I understand fully now.
It's surprising what a picture will do isn't it????
Neil
Old 02-17-2011, 03:58 AM
Hodgey, Try Sam's Club if you have one near you. About $20 cheaper than AutoZone, at least a year ago. Also, if you do drain it down, do a jump start, then charge it overnight on a regular charger. This seems to be the biggest detriment to this battery. I have had great luck with this battery for about 15 year, boats/Porsches but some people have had problems lately. Good luck. Steve
1970 911T SOLD
1989 3.2 Carrera
2013 991 Carrera S
Old 02-17-2011, 04:57 AM
The 9 Store
Costco also has good prices.
Old 02-17-2011, 05:25 AM
I've had one in my 89 3.2 for almost 8 years now, has worked very well. There are some sleds available so you don't have to make a custom one. I made one from a plastic cutting board.
Old 02-17-2011, 06:49 AM
The biggest problem seems to be that a fairly depleted unit needs a "kick in the pants" to get going again....something like a very high rate charge for a few minutes or so...and then followed by a normal or trickle charge. Look at their website or google it....it seems to come up every once in a while.
Yes...pics help to describe what takes longer in words ! .... ...thnx.
Wil Ferch
Old 02-17-2011, 07:04 AM
Hodgey's Avatar
Thanks Steve...I have one really close by....
Neil
Old 02-17-2011, 03:37 PM
