hidden attenna recommendations?
I may need to replace windshield soon, but I heard the better route may be a powered internal antenna ( & Cheaper glass) rather than the pricey windshield with the marginal antenna built in.
Does anyone have any experience with these? the last relevant post i found was from 2003.
amazon has one for 20 bucks,
Old 02-17-2011, 10:51 AM
Checked out
McLovin's Avatar
I used one of those fairly inexpensive powered ones that you stick on the windshield in a prior 911. A piece of black plastic maybe 8 inches long or so. It worked about the same as the factory "in the glass" antenna in my current 911 (i.e., marginal, as you point out, but workable).
Old 02-17-2011, 10:56 AM
kent olsen's Avatar
Years ago I found one at Radio Shack. It was in a clear tape, like scotch tape. that I ran up the outside and top of the windshield up to the rear view mirror. It's worked for at least 10 years.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 02-17-2011, 11:22 AM
AutoBahned
RWebb's Avatar
another option is a hidden antenna in the trunk
of the 3 options I have no idea which would be best, tho the trunk ones have the metal trunk around them...
Old 02-17-2011, 11:40 AM
