1980 911 SC
That's too funny.
1.5 ounces of Marine Stabil every tankfull. Can't say if it works.
Life's a Beach |
AHHHHH !!!!! California the land of the bankrupt and the Greene's.
Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. |
Flat Six
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Gas Huffer
Race gas (ie Sunoco at Thunderhill or Infineon) is at ~10.0% Ethanol in the state of CA. Its only ethanol-free if you purchase it in 55 gall drum or small gallons from a supplier for offroad purposes only, such as for dirtbikes, ATVs, etc. Even then you need to sign your name for it along with proper paperwork! CA has only had 10% ethanol since Jan 2010. It was at 5.7% for many years before that. The current CA State policy: http://www.arb.ca.gov/fuels/gasoline/082908CaRFG_regs.doc Look up section 2262.6 if you are interested.
67 Porsche 912R-STi - Betty White - Instagram: @912RSTi 69 Porsche 911T - Project 04 Ford F-150 FX4 - Boris |
Now we may have E20
![]() E20 is just fine for fuel pumps, says Minnesota Ag Department — Autoblog Green The Center, which operates out of Minnesota State University, Mankato, just released a study that found an E20 blend "causes no significant change in performance of automotive fuel systems." This study, the fourth E20 project the Center has conducted, was all about the fuel pumps and sending units. Eight models of fuel pumps were run for 4,000 models on three different fuels (pure gasoline, E10 and E20).
John D. 82 911 SC Targa-Rosewood 2012 Golf TDI |
Note the highlighted text. Great, my fuel pump and level gauge will live! what about my loss in performance due to the lowered energy content of a gallon of fuel (i.e. worse gas mileage). The strain this fuel will put on my overburdened fuel mamangement system which will need to richen the mixture even more to operate at stiochiometric ratios. How will the resultant lean running impact my catalyst? It is interesting to note what was omitted or overlooked in this research. They did not say E20 has no or postive impact to overall perfomance nor it's impact to anything OTHER than fuel pumps and level gauges. Why did they not factor in the loss in performace due to the changed A/F Ratio? How E20 afftect tailpipe emissions.
Max Sluiter
"significant"
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
The study found that the pumps showed significantly less wear when tested with E20 than with gasoline. The study concluded that overall, E20 did not have any greater negative effects than gasoline or E10 on the fuel pumps tested. It also showed there were no substantial differences in the performance of the sending units tested in the three different fuels.
Since the only issue I need to care about in my car is if the fuel gauge works and my fuel pump works ok, I can now rest easy knowing that E20 is superior to the other currently available fuels. After all, why would I worry about trival things like fuel economy, deviation from Stiochiometric A/F ratios and other performance parameters. FYI, I started a new thread on ths topic as it needs to be highlighted. http://forums.pelicanparts.com/porsche-911-technical-forum/599932-heck-e10-lets-go-e20.html
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 03-29-2011 at 06:17 PM.. Reason: link to new thread |
the question is not whether we can buy ethanol free fuel. there are almost none. the total list represents less than 1% of the gas stations in Houston alone. There are virtually no stations in the 5 largest Texas cities and we are the oil refinery capital of the world. That is because E10 is federally mandated. I suspect that if you test most of those stations on that list you will fine ethanol. despite the stickers on the pump. is marathon really manufacturing ethanol free fuel for your one small station? the marathon gas in houston absolutely has ethanol.. and its refined here. not likely your small station has a deal for ethanol free fuel. its much more likely the pump is labeled wrong. id love to see some test results.
the real question to be addressed is what we need to do to our cars to preserve them and allow them to run properly. Jaime is already instructing those with MS EFI to alter the AFR and VE tables to accomodate. I think he multiplied his AFR tables by .94 and his VE tables by 1.06. On MFI, CIS, Motronic systems it may be good to think through and test likely scenarios. I think the old AFR targets of 14.7 go out the window and targets in the low 13's become likely. example, my car runs like crap at idle at wideband control of 14.7. I am running 12.8-13.2 and have a smooth idle. As soon as i go north of 13.5 i get severe lean symptoms. If we use our old AFR targets we will be extreme lean at higher RPM's. (I run Chevron 92) I have a hotter cam so not ready to say its all fuel related... but the AFR/VE tables have to be impacted. So rather than hand wringing... i would have the pros do some testing to see what optimal AFR/VE tables / values look like for Gas, vs E10, vs E15, vs E20, etc. We have a few years before the oil companies could even do E20... so no need to panic...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 03-29-2011 at 07:44 PM.. |
Marathon Oil Company is marketing a 90 octane unleaded non-ethanol gasoline as a recreational fuel for boats. This fuel is perfectly suited for use with 87 octane auto fuel STC's. In some locations it is one octane point higher, 91 octane. 91 octane is suitable for use with all auto fuel STC's. Marathon ethanol free 90 or 91 octane may be available at the following bulk product terminals: * Ft Lauderdale-Eisenhower * Ft Lauderdale-Spangler * River Rouge, MI * Detroit, MI * Romulus, MI * Doraville, GA * Powder Springs, GA Pilots living near those areas of FL, MI or GA should contact the terminals to find out where this "Recreational Fuel" is being distributed since not all Marathon stations are carrying it. Last edited by Danny_Ocean; 03-29-2011 at 07:45 PM.. |
So your not using Auto fuel.
This is like Race Gas. Speciality product. Doesnt really help 99% of us... altho its a great find. ![]() Quote:
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 03-29-2011 at 07:52 PM.. |
is there any downside to using "recreational fuel".
Should we all be looking for it? Im on the gulf coast.. I could look to see who is selling similar gas here... Is this like the Heating Oil vs Diesel debate? Up north we had Hess stations that sold both. Of course the Heating oil was 50% less and many stated it was the same stuff... Quote:
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Here are all the stations in TX: Ethanol-free gas stations in the U.S. and Canada |
you are missing the point.
are there other things in Auto fuel (like Techron, detergent packages) that is missing from Recreational Fuel? Is the formulation otherwise compatable/comparable? I get that there is no ethanol. That is obvious. Quote:
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 03-29-2011 at 08:03 PM.. |
Gas Huffer
Depends on the race gas you purchase. Here is Sunoco's Spec Sheet for 97+ for on road use:
260 Gold - Unleaded Race Fuels It states on the left side that they have a detergent additive in it. You can look through their other fuels on that site as well. "Offroad use only fuel" may have Lead in it. Be aware. Marathon states they use STP in all their branded fuels, so I suspect that Danny_Ocean received fuel with additive, just no ethanol. http://www.marathonpetroleum.com/Products/Marathon_Brand_Gasolines/
67 Porsche 912R-STi - Betty White - Instagram: @912RSTi 69 Porsche 911T - Project 04 Ford F-150 FX4 - Boris Last edited by MichiganMike; 03-29-2011 at 08:18 PM.. |
