masterdave's Avatar
new car what oil should i use
I just bought a 1978 911sc targa turbo, it has 140,000 miles on it with a rebuild done about 20k miles ago.
what oil should i be using for the summer months, I live in westchester NY it never gets up above 100F on the worst of days, usual around 85-95F
Also, what type of trans fluid should i use, where do i drain the trans from, where do i fill it from
Dave
Old 04-27-2011, 12:47 PM
PCA7GGR's Avatar
It might be a good idea to ask the mechanic you plan to use to service it.
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 04-27-2011, 12:58 PM
masterdave's Avatar
i do most the service my self but I will ask one of the mechanics i know, i was wondering what other people ran in there cars.
Old 04-27-2011, 01:23 PM
Northern Motorhead
wildcat077's Avatar
Dave,
Best advice i could give you is to buy a Bentley manual for your particular car and read it over a few times before you attempt any servicing ...
You have to be careful because parts are expensive.
There is a lot to learn about a Porsche car,eventually you will enjoy working on it yourself.
As far as oil goes,i would go with a good 20W50 oil,do a search,there are endless posts on the subject !!!
Cheers!
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 04-27-2011, 01:24 PM
schumicat's Avatar
there are about 100 threads on what type of oil and trans fluid to use, which you can find using the search function.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 04-27-2011, 01:32 PM
dshepp806's Avatar
What's presently being used?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-27-2011, 03:53 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Engine
10.5 quarts: Valvoline VR1 20W50 (non-synthetic)
Mahle OC54 Oil Filter
Drain Sump and Crank
Trans:
3.5 quarts: Kendall 80W90 ( if you have LSD, 80W90 with LSD Additive) 1 fill/check level 17MM Allen Bolt on the side and 1 Drain 17MM Bolt at the bottom. Just make certain the fill bolt can be removed before draining the trans, it need to be removed FIRST!
+1 on Bentley, 101 Book or at least Haynes for Torque Settings
'85 Carrera Targa
PCA/POC
Old 04-27-2011, 04:09 PM
Senior Advisor
James Brown's Avatar
Besides the Valvoline, Swepco and Brad Penn are the other choices. Check with LN Engineering for others. Do not stray from these choices.
08 Cayenne Turbo
Old 04-27-2011, 04:30 PM
kramer747's Avatar
Castrol 20W-50
Old 04-27-2011, 05:47 PM
Gerry van's Avatar
Haven't l been on this merry go round before....
Old 04-27-2011, 06:15 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Engine - Mobil 1 20w50
915 - Kendall (w/LSD additive or not)
Get a small NAPA oil pump for the tranny, makes it a LOT easier to fill. Also always remove the fill plug before draining, it's a ***** if you drain it and find you can't get the fill open...
Gary R.
Old 04-27-2011, 07:02 PM
HarryD's Avatar
Oil selection generates lots of discussion.
Originally Posted by HarryD View Post
Long answer:
http://forums.pelicanparts.com/porsche-911-technical-forum/367300-ultimate-motor-oil-thread-why-we-hate-cj4-sm-oils.html
Cliff Notes version:
Buy and use whatever you want. It used to be true that "oil is oil". But be aware that motor oils have changed and not for the better.
A bit of history:
Prior to the mid 90s most cars on the road had flat tappets to actuate thier valves. It turns out there is a huge amount of pressure on the tappet/cam surface when it is actuated. This effect was discovered in the '50's (I may have the wrong decade but you get the picture) and a minor outfit called SAE noticed that cams were wearing out very quickly.
SAE paid some PhD's to do some research. They published lots of research papers and found out about these high pressures. They also found that a Zinc/Phosphorus additive known as ZDDP would provide protection to these parts at a resaonable cost. Gosh those guys were smart!
The SAE folks spoke with the API folks and asked if they could require ZDDP added to their required oil formulations to increase the service life of these critical components. Much to the pleasure of SAE, API agreed and based on the PhD recommendations, required about 1200 ppm of Zinc (Zn) and Phosphorus (P) added to oil formulations so the oil maker can get his product API certified.
This worked great but then in the 90's car makers went to more expensive Roller tappets which offered the advantage of lower reciprocating losses in the engine (i.e. better gas mileage). The use of roller tappets became standard in cars in the mid-90's.
In the early 2000's, the USEPA (for what ever reason) became concerned that the Zinc and Phosphurus in the oil would partially exit the engine via the tail pipe. This is a big deal since these two elements tend to kill the catalytic converters and, in theory diminish their service life. As a result EPA wanted the reduce the Zinc and Phosphorus in motor oils.
Fortunately (for EPA), car makers had already gone to roller tappets. Again the PhD's went to work. The clever PhD's found that the roller tappets do not exert the high pressures that flat tappets do. They did some more reaserch and found that for car with Roller Tappets, you could safely reduce ZDDP to a much lower level with no adverse impact on cam service life.
This change was codified in the API SM/CJ4 (and newer) oil standards. And while some formulations are permitted to have higher Zn and P, the cost of ZDDP relative to base motor oil is much higher and if the oil maker wants to save some money (i.e. increase profit or lower price) he merely needs to reduce the use of this relatively expensive additive and still claim conformance to API requirements.
Older engines (pre-mid 90's) STILL need high levels (around 1200 ppm plus correct level of detergents) of Zinc (Zn) and Phosphorus (P) to protect cams and other high pressure surfaces.
Use 20W-50 or 15W-40 oil. Brands frequently sugggested here, in no particular order, include:
Brad Penn 20W-50
Valvoline VR-1 20W-50
Kendall GT 20W-50
SWEPCO 15W-40
Royal Purple
Redline
Motorcycle Oils
There are others as well.
Also much debate but most feel SWEPCO 201 or Kendall as noted above. To change, here is my story:
I'm a cheapskate.
I just use a funnel and gravity.
Changing the Oil in an Early 911 Transmission
This is a better plan than mine.
thanks to jadams1.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-27-2011, 07:20 PM
GaryR's Avatar
Mobil 1 V-Twin 20W50, 1600PPM .... that's what I use.
Gary R.
Old 04-27-2011, 09:38 PM
Senior Advisor
Notice Mobil-1 is not on the list (except there motor cycle oil) Why?
08 Cayenne Turbo
Old 04-27-2011, 11:03 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
motorbikes don't run cats, and maybe they run solid lifters so they need the same oil additives that our early cars do?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 04-28-2011, 03:29 AM
kramer747's Avatar
I have been told by p-mechanics not to use Mobil One in the older 911's because it tend to migrate to areas where it shouldn't and create leaks? It didn't leave the factory with Mobil 1
Old 04-28-2011, 05:49 AM
GaryR's Avatar
Mobil 1 creates leaks? Find new "p-mechanics".
Gary R.
Old 04-28-2011, 07:00 AM
jdbunda's Avatar
Read the Ultimate Oil thread linked above. The problem with Mobil 1 and may other current oil formulations are recent formula changes that do not provide enough phosphorous and zinc for older engine designs.
Old 04-28-2011, 07:03 AM
GaryR's Avatar
I believe their 20W50 "regular" does (1200PPM?), know their Racing oil does, and their V-Twin 20W50 is very high at 1600PPM (advertised).. Brad Penn is fine for a road car, I noticed increased temps (20-25%) on track using it, NG for my particular car. May try it in my hot rod but doubt it.
Gary R.
Old 04-28-2011, 07:08 AM
HarryD's Avatar
+1. I think back inhte day (when Synthetic oil was first introduced), this was an issue for some cars. Since those days, time has marched on and the synthetic formulations have changed to elminate this as an issue.
At this point in time, I feel that the dino vs syth issues are mostly academic. In regular service (99% of the cars out there), it does not matter which oil you use as long as you have the proper additve package for antiwear, etc. Due tot he higher temperature tolerance of synthetic oils, those highly stressed engines (race cars, for example) may see a slight benefit from synthetic (group IV and V) oils due tot he better tolerance of excessive heat.
No, I am not a lubrication expert but I have stayed at a Holiday Inn express!
Harry
2020 MB E350 4Matic
Old 04-28-2011, 07:59 AM
