Oil Spritz Out Exhaust / No Smoke / Ideas?
Fellow Pelicans, when I start my 88 911, there is oil (or something wet) spraying/misting onto the pavement. Very small droplets or particles. I have been reading the board and haven't seen this issue. There is no smoke. Any ideas?
note: I accidentally posted this in the 944 forum section, so this is a re-post. One response from the 944 forum came back with a suggestion that the car could be running too rich. Thank you in advance! Trent |
It could just be condensation in the exhaust system that's being spit out when the car starts. Obviously there's no water cooling, so if it's not oil likely it's condensation. Even though it might be grimy, I suspect it feels less "slippery" than oil.
My $.02. YMMV. Scott
1984 Targa |
Jupiter 911
+1 on the condensation, mine will do the same when its started from cold.
Lenny-1987 3.2 Targa Guards Red/SW Chip Fabspeed Exhaust/Cat bypass MSDS Inc. intake/Clewetts Euro pistons and cylinders. 2002 Boxster Artic Silver/Wifes ride. |
+1 Condensation.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
Member 911 Anonymous
+1, normal. Just make sure it is not doing that when engine is hot.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thank you all for the input.
Prior to a DE this past weekend I took the car for some minor work, and the mechanic suggested I might need something done...typical. Pelcanites Rule!
'88 911 Coupe (sunroof delete) / FRP/Carbon Front Fenders & Bumpers / Elephant Racing Suspension / 3.4L Motor Conversion |
Schleprock
Cold exhaust pipes + warm engine exhaust gas = condensation on every car. Key is to make sure you take trips long enough to burn it off. Most cars have mufflers with purposely placed holes in them to drain the exhaust of condensation. However the 911 banana muffler doesn't have any drain holes. So it's good to make sure most trips are long enough to burn it off and reduces the opportunity for muffler to rust-through on account of the condensation rich with exhaust gases.
Kevin L '86 Carrera "Larry" |
