-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   PCV 3.2 Does she need it or TEMINATE? How? (http://forums.pelicanparts.com/showthread.php?t=614095)
DRACO A5OG 06-14-2011 10:20 PM
Hey Fellas,
How many of you have Capped Off or Terminated the PCV. Pics Please ???
Today my wrench told me if it fails it will mess with the idle, creating a vacuum leak of sorts.
What are your experiences?
Can it be cleaned?
PCV & Rubber Sleeve "baffle" are NLA PAG or PPB so that sucks :eek:
Compliment of GH85Carrera:
http://forums.pelicanparts.com/uploa...1293134614.jpg
TIA
DRACO A5OG 06-14-2011 10:27 PM
Oh Crap, FLAPS has it for $9.99 :eek:
http://contentinfo.autozone.com/znet.../4298/image/2/
and the Baffle, I can't believe it:
http://contentinfo.autozone.com/znet.../5333/image/2/
Flat Six 06-15-2011 09:45 AM
Hey DRACO, you have a part number / source for the PCV valve?
TIA
Dale
DRACO A5OG 06-15-2011 10:07 AM
PCV AZ# 4298 $9.99
Baffle AZ#5333 $9.99
Special Order to home or store.
Flat Six 06-15-2011 10:34 AM
Originally Posted by DRACO A5OG (Post 6081084)
PCV AZ# 4298 $9.99
Appreciate it, bro -- thanks.
DRACO A5OG 06-15-2011 11:29 AM
Just order mine at store in 2 days :D
GH85Carrera 06-15-2011 12:01 PM
Hey that photo looks familiar! :)
DRACO A5OG 06-15-2011 12:02 PM
Hey Glen, hope you don't mind?
BTW, what did you do with your PCV???
Jim
DRACO A5OG 06-16-2011 08:56 PM
Update: The Baffles will not work, but the PCV looks proper, will install and report
DRACO A5OG 07-27-2011 09:29 PM
Installed, no change.
Next Fuel Pressure Regulator (FPR)
Quicksilver 07-28-2011 05:45 AM
As a rule removing a PVC valve by blocking it off will cause an engine to build up pressure in the crankcase causing it to leak oil like crazy. The layout of the oil system of the 911 motor is a fair bit different from the average wetsump system but I can't see how it could avoid the same problem. If there was any openings that could release the crankcase pressure those openings would also allow dirt into the system.
So either you must have a PVC (which you have found for cheap) or you must have a breather (which would fail emissions).
Jonny042 07-28-2011 07:08 AM
I may be wrong, but thermo swtich on the TB opens the path to that hose only during cold weather.
The two large hoses provide all the pressure relief you need, and the vapors are fed into the intake. The entire crankcase/oil tank is under "semi" vacuum, the vacuum that exists after the AFM, but not full intake vacuum that exists after the throttle plate.
FWIW, mine is blocked off. No ill effects.
E Sully 07-28-2011 10:08 AM
It's to prevent icing on the throttle body in cold temps.
I just capped it off on my 3.2, but I don't drive it in cold weather.
http://forums.pelicanparts.com/uploa...1311872898.jpg
DRACO A5OG 07-28-2011 10:14 AM
Do you have a pic of the cap off? SoCal has no icing issues :D
big911fan 07-28-2011 02:27 PM
Hose Clamps
I don't want to intrude on this post put the picture of the PCV with the hose clamps got me wondering. I've never tried to remove that type of hose clamp. Is there a secret?
It looks like it takes a special crimper to replace with the exact type clamp. Do you just open it with a screw driver or something and replace it with a conventional hose clamp? Thanks.
DRACO A5OG 07-28-2011 02:42 PM
Oh No intrusion Brother.
Yes indeed it uses a special crimper or a Wire Nipper $12.00 at an Hardware store. BUt only to crimp on, it needs to be destroyed if removed to get it off. So I used the nipper to cut it off but used a Standard hose clamp to put the new PCV valve on around the OEM baffle.
1990C4S 07-28-2011 04:24 PM
Oetiker clamps. Easy to put on. Not easy to re-use.
Pliers are shown as 'manual closing tools' on this page:
Installation Tools Products Clamps and Rings OETIKER International
Buckeye 05-12-2013 01:29 PM
Thanks for the info I will call a dealer tomorrow.
Pasophisto 06-05-2013 12:07 PM
What is FLAPS?
I need those parts:
PCV AZ# 4298 $9.99
Where do I get them?
SMS
DRACO A5OG 06-05-2013 12:24 PM
FLAPS = friendly local auto parts store
Found it at zone de auto :-D
