XLR8'd Member
David 84 911's Avatar
Tire with a plug safe for lapping ?
I have a track day with the Porsche Club and have a rear tire with a ply from a small puncture I had. Would you go lapping like that or buy new tires. I prefer to wear these first. Thanks
David (mechanic wanabe)
2002 Carrera 4S (replacement for an 84 coupe)
06 Acura CSX (wife beater)
05 Acura MDX (toy hauler)
http://www.pelicanparts.com/gallery/david_84_911
Old 08-01-2011, 05:43 AM
Northern Motorhead
wildcat077's Avatar
David,
Personally i wouldn't even trust a plug on my trailer ...
At the least,go to a good tire shop and have them install a vulcanized patch on the inside
of the tire.
You will have to pay for rebalancing but that's a small price to pay as compared to scrapping a wheel because your tire ran flat !
Since you're from Montreal,call Manuel at Pneus Touchette,they're always at all our Rennsport track events ,they can probably repair it at the track for you !
Not sure if they're at Calabogie,but they're always there at Mont Tremblant ...
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 08-01-2011, 05:59 AM
175K911's Avatar
Plug or patch-plug?
And where on the tire?
If it's just a plug, no way I'd run it on the track. A patch-plug is applied from inside the tire- it's a patch with an attached plug that is pulled out through the hole. But I believe most of the tire manufacturers state that patching a tire effectively negates the tire's speed rating.
Personally, I don't take a repaired tire on the track. Failure of a $200 tire can have far more expensive consequences.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Spiderman
Jesse16's Avatar
I would use em. I've never had a problem with tire repairs myself. Others will argue to consider safety above all else so it'll be your call. (I think some just like an excuse to spend more money on equipment which I just can't do) My opinion, tire punctures can happen "any" time so your "new" tire may puncture on the first lap or on the drive to the track. Does that make it un-useable also ? Gotta go with what makes you comfortable. I'm more willing to trust the rest of the tire to hold just fine.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 08-01-2011, 06:00 AM
XLR8'd Member
Great guidance. Thanks !
Old 08-01-2011, 06:07 AM
175K911's Avatar
From the TireRack website:
Tire Tech Information - Flat Tire Repairs
Ed
Old 08-01-2011, 06:40 AM
Recreational User
porschenut's Avatar
If these are R compound track tires, I'd say no. But if they are normal street tires I think you'd be fine, but monitor it closely throughout the day. The tire might go flat, but you won't have a blowout because of a plug. For a DE or lapping day on a stock or mostly stock car with street tires, you'll hardly put more stress on them than you would driving aggressively on the street.
Old 08-01-2011, 07:14 AM
disband
juanbenae's Avatar
it's one of those "if you have to ask" you prolly already know the answer...
Old 08-01-2011, 07:39 AM
MBruns for President
JeremyD's Avatar
I've had a flat tire on the track - luckily I heard and felt it at the same time - got a spin in - but that's it. I would not run a tire that's been repaired.
I have a rule that I follow to a T.
If it involves Tires/Wheels/Brakes/Suspension - there are no compromises.
Old 08-01-2011, 08:17 AM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
email the club responsible for the event and ask them.
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 08-01-2011, 08:24 AM
vracer's Avatar
Originally Posted by 175K911 View Post
Great info; thanx for posting it.
Richard
1989 Venetian Blue Targa
Old 08-01-2011, 08:54 AM
Living up to the name
VroomGrrl's Avatar
Read your club's rules for the event, the tech stuff in particular. Most high performance events prohibit running patched or plugged tires.
2008 911 (997) C4 Carrara White
The sweet old 1988 911 GP White has gone to a new owner
"Keep your head in the clouds and your right foot mashed to the floorboard!" ~Village Idiot
Old 08-01-2011, 08:29 PM
Only to share... i have been doing my own string tire repairs with 100% sucess for 30 years. This includes my highly modified 928 running countless laps at Pocono at 147 MPH and my quite improved 911s doing more than 2 seasons with several plugged 245/45-16 Bridgestones (building house..see?).
This is only my experience....consider other feedback and ...assess,
Best of Luck.
Old 08-01-2011, 10:01 PM
Spiderman
Jesse16's Avatar
String Repair ++
Actually thats how I repair all the tires on my vehicles, living in the burbs I'm always hitting a small nail, screw, or staple. Always a satisfying 15 minute activity and 100% works, has never failed me. Probably 25 repairs total. Haven't actually had a flat on the 911 yet but I'd repair if the tread is still decent.
Old 08-02-2011, 05:49 AM
Prior to my first DE, I ran over a key(yes, a key!) that went through my tire. I removed the tire and had it patched at the local gas station. I don't even think it was a patch, more like an old school plug. And then I ran that plugged tire for the next year with no incidents.
What level are you driving? For green, you should be fine. As you approach black or red run group status, I would be more concerned. (BTW - These are the levels our PCA region uses).
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 08-02-2011, 08:41 AM
dgmark's Avatar
A Plug will work fine till it fails, No Tire manufacture recommends plugging a tire. A proper repair is a patch plug with an inspection of the inside of the tire.
30 Year ASE Master Certified Technician
1986 911
Old 08-02-2011, 09:47 AM
Platinum Member
dad911's Avatar
Ever see a car hit the wall because of a tire failure? I have, and it ain't pretty.
If you're in an instructed group, why don't you ask your instructor if he will be comfortable riding with a plugged tire?
Old 08-02-2011, 10:48 AM
AirKuhl's Avatar
From Michelin, although a pretty long time ago and I have no idea if their policies have changed since:
Subj: Reply From Consumer Relations
Date: 11/22/2002 11:47:55 AM Eastern Standard Time
To: XXXXXX
For tires with a speed rating of 130 MPH and higher (H,V,Z) only one (1) ¼"
(6MM) diameter puncture may be repaired and allow the tire to retain its
original speed rating.
It is essential that a trained tire dealer or repair person deflate and remove
any tire from the wheel when it has been damaged or loosing air. A thorough
inspection for any internal damage must be made. Never perform an outside-in
tire repair (on the wheel). For proper repair procedures, refer to RMA's
Puncture Repair Procedures for Automobile and Light Trucks.
If you have additional questions, please respond to this email
or you may call us at 1-800-847-3435 (toll-free) between
8:30AM and 6:00PM Eastern Time Monday through Friday to allow
one of our Consumer Relations Representatives to assist you.
Michelin North America
Consumer Relations Department
(Please Do Not Delete the line below.)
Email ID: 862819
FWIW, I have done several track days with a properly plug/patched and rebalanced rear Michelin PS2 on a 993 C4S with no issues. YMMV.
--Pete
Gertrude
Black Betty
Voodoo Child
Old 08-02-2011, 11:08 AM
Nine9six's Avatar
To: XXXXXX
Email ID: 862819
Completely off topic...Pretty impressive stable you have there, Petey! I am refering to Gertrude, Black Betty, & Voodoo Child.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 08-02-2011, 11:48 AM
peppy's Avatar
I would think there is more to a patched tire than just air loss. There could be structural damage to the cords and plys of the tire.
I would save the tire for street use, but never on the track.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 08-02-2011, 11:49 AM
