1972 911T/S MFI Survivor
Old 09-08-2011, 10:22 AM
Grady: - you're right as usual. Here's a couple of mine:
Old 09-08-2011, 10:26 AM
Max Sluiter
Flieger's Avatar
What is the recommended redline on these motors? Was it different for early motors compared to the 587/3? I understand that racers would often overrev them back in the day since it was faster and they would survive a while like that.
Old 09-08-2011, 10:44 AM
Old 07-23-2012, 11:11 AM
tazzieman's Avatar
Originally Posted by DAEpperson View Post
Evil lurks behind! Outstanding, where dya find that?
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 07-23-2012, 03:07 PM
It was posted in the Engine Porn thread. I was hoping someone would know something about it.
Old 07-23-2012, 03:12 PM
Make Bruins Great Again
Por_sha911's Avatar
Originally Posted by chris_seven View Post
Any camshaft will suffer from torsional vibrations and they are parametric in nature and self-induced. These vibrations will cause dynamic phase errors in the valve timing and it is unlikely that a distributor advance curve could compensate.
To resolve the phase changes involves some quite tricky non-linear differential equations even at constant speed and when you add in angular acceleration it is even more difficult.
The biggest problem of all would be if the cam were to be excited so it reached its natural frequency as it would then go completely out of control and perhaps even snap.
Obviously the less the number of lobes on the cam the greater the ratio of peak to mean torque and the more the phase variation. and hence the likely reason for the use of flywheels.
Does a four cam, four cylinder engine with two valves per cylinder only have two lobes per cam?
The variation in torsional load will affect the complete driveline of the cam. The bevel gears themselevs will be relatively stiff compared to the shafts and can probably be neglected.
The type of follower used will also have a signifcant effect as the coulomb damping associated with flat tappets will tend to damp any harmonics.
All that sounds like:
Joe
Old 07-23-2012, 06:59 PM
tazzieman's Avatar
The 4 cam 's success was directly related to the enhancement whereby
it may be employed in conjunction with a drawn reciprocating dingle arm to reduce sinusoidal depleneration
Old 07-23-2012, 07:52 PM
závodník 'X'
intakexhaust's Avatar
Bigger question is, why in there?
Old 07-23-2012, 08:30 PM
tazzieman's Avatar
Maybe has one of these?
Brand New Porsche 4-Cam Engine Anyone? | The Chicane
Old 07-23-2012, 09:53 PM
Agreed - think of that high-reving engine hooked to the gear reductions on each wheel?
Old 07-24-2012, 09:27 AM
Here is one some of you that live in the NW might have seen before.... Rumor is he traded it for a pushrod motor in the 70's.
Old 07-24-2012, 10:56 AM
Wonder where they put the dry sump?
Old 07-24-2012, 10:57 AM
It's under the back window all polished up. Wish I had a picture here at work. That bug also has the gauges and brakes from a 356.
Old 07-24-2012, 01:24 PM
muck-raker
kidrock's Avatar
I'm sure they pulled the old reduction box trans and replaced it with a re-geared ("freeway flier") trans with half-axles and CV joints.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 07-24-2012, 06:57 PM
Call 911
dkirk's Avatar
It looks like this beautiful engine will be back in limited production again - not from Porsche but from Capricorn Automotive GmbH of Germany. The expensive Hirth multi-piece crankshaft with roller bearing crankpins has been replaced with a single piece forged crank with conventional pressure lubricated journal bearings. Otherwise, the engine is a virtual duplicate of the original. Here is a link to their site:
http://www.capricorngroup.net/fileadmin/files/images/capricorn_Anzeige_Motorsport_UK.pdf
Dave Kirk
My Porsche restoreth my soul.
Old 08-03-2012, 08:08 PM
Old thread I know, but if you've ever lusted after a Fuhrman 4 cam, now's your chance.
(And, FWIW, the comments on this one are extraordinary. Sure wish Grady was still around - sigh...)
https://bringatrailer.com/listing/porsche-fuhrmann-four-cam-engine/
Old 09-12-2024, 09:57 AM
Have you guys seen this yet?
Old 09-12-2024, 10:19 AM
Steve F's Avatar
Thumbs up
Wow!!
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 09-12-2024, 10:51 AM
GG Allin's Avatar
That's Perfect Power building that motor.
1988 911 - 3.6
1999 SL500 - Gone
1995 M3 - LS2 - Gone
1993 RS America - Gone
Old 09-12-2024, 12:07 PM
