fbeatty's Avatar
Alternator or V-Regulator question
OK, took the car out for a drive the other night and the stereo started acting up, then the lights (evening was just falling). Got it home and the battery was real low. Charged the battery up to 12.6 overnight.
Started the car and the voltage held at 12.2. Took the RPM's up to 2000 and the voltage across the terminals stayed at 12.2 no increase. The alternator light does not come on.
According to Bentley, this indicates the voltage regulator is at fault. Is this correct, or did I miss something? Should I replace the alt and regulator? Does a reman Bosch come with a new regulator?
Apologies for all the questions, but I really don't want to spend the extra $$$'s if it is not needed. I know with the knowledge bouncing around this board the answers will probably be right on the money.
Thanks in advance,
Fred
Every cloud has a silver lining (except for the mushroom shaped ones, which have a lining of Iridium and Strontium 90)
08 Cayman, 88 911 Targa, 93 MR2 Turbo, 2012 Jeep JK
Old 09-06-2011, 05:02 PM
RETIRED
Joe Bob's Avatar
Does the light work with motor off but ignition on? If not, replace it. It's part of the charging circuit.
Old 09-06-2011, 05:22 PM
fbeatty's Avatar
Joe Bob,
Thanks for the quick response.
Ignition on/motor off, light is out. Will replace the bulb and let you know. Thanks for the catch.
Old 09-06-2011, 05:25 PM
plumb4u2's Avatar
I agree it is the VR....I just had this happen
You can replace only the VR but it is bout $80
Your best option would be to take to a local Alternator shop and have them rebuild yours....should only cost 100-150
Justin
84 Carrera Targa
98 F-150 4x4
Old 09-06-2011, 05:28 PM
fbeatty's Avatar
Just pulled the bulb. The element looks fine and there is continuity through the bulb, but it does not come on.
Old 09-06-2011, 05:52 PM
fbeatty's Avatar
Update confirmed bulb is good, went to put it back in the tube and the metal on the bulb touched the metal on the tube and the bulb lit right up.
Old 09-06-2011, 06:00 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Check your voltage again when running. Should be closer to 14v and remain steady.
Old 09-06-2011, 06:04 PM
fbeatty's Avatar
Bob,
No luck, without that mistaken contact the bulb does not light up. Even with it lit (mistaken contact being kept to keep light on) , the voltage stays constant while the engine is running and drops by a couple of hundredths when RPM's are increases.
Old 09-06-2011, 06:14 PM
Send a message via Skype™ to Porboynz
There is one other easy check to make and thats the earth wire to the fuse/relay panel in the engine bay on the lhs. If you have a regulator mounted on that panel and the panel earth wire falls off the alternator stops charging and the idiot light stays off. (The panel is rubber mounted) Of course if your regulator is on the rear of the alternator then this does not apply. Pull the alternator and check the slip ring brushes before you visit the auto electrician or order another alternator, bushes are another cheap fix if the bearings etc are still all good.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 09-07-2011, 12:40 AM
In your '88, the VR is integral to the Alt. Get a new one or rebuild the one you have, I'm not sure you can replace the VR alone, but a rebuild shop probably can.
Old 09-07-2011, 05:06 AM
Bob Kontak's Avatar
The dancing banana says the bulb is integral to the system. A couple of hundredths is all the variation you should see. What is THE voltage?
Old 09-07-2011, 08:56 PM
fbeatty's Avatar
SUCCESS!!!! I finally broke down and bought a new (reman) alternator from PP. Or more correctly, my wife told me to get off my tight a$$ and get a new one. Installed it, the light is working correctly and the voltage across the the terminals is 14.2 - 14.35.
Old 09-16-2011, 09:00 AM
KNS KNS is offline
Good going! Thanks for posting back...
Kurt
Old 09-16-2011, 09:06 AM
