Captoz's Avatar
Help! Gear shift bushing!
Have stuck a snag replacing the bushings on my 1977 911 5 speed. How on earth do you get the shifter rod bushes out! Have removed the shifter and the rear coupler and replaced those parts ok but the bush on the shifter rod is fighting me. Do you slide it all the way to the rear of the rod? What gives.
Wayne you said it was easy in the book! How do you remove the sucker?
Any Help greatly appreciated.
James in Oz.
Old 09-16-2011, 09:24 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Post a pic
'85 Carrera Targa
PCA/POC
Old 09-16-2011, 09:28 PM
Captoz's Avatar
Pic of new bush and shifter rod with bracket and old bush still in the tunnel
Originally Posted by DRACO A5OG View Post
Post a pic
Old 09-16-2011, 09:36 PM
DRACO A5OG's Avatar
Well, on my 3.2, you have to remove the set screw of the shift rod coupler, remove the coupler then slide the bushing assemble forward and off.
Snap off the old bushing, place new bushing and replace in reverse order.
'85 Carrera Targa
PCA/POC
Old 09-16-2011, 09:49 PM
Captoz's Avatar
All done. Didn't see the screw to release the neck part. Shold have read my drawings a little more closely.
Now to put it all back together. Heres to smoth shifting.
Thanks again
James in Oz.
Old 09-16-2011, 10:23 PM
