| Registered |
				Spare Tire Question
			Today, I try to put air in the spare tire, but I was not able to do so? Is there a special tool to do this? I have included a few photos of what the tire looks alike right now, WTF? It's going on here???
				__________________ 10.76@139-1/4 mile 0-1 mile 193MPH I Love to Shine Cars   | ||
|  09-16-2011, 04:50 PM |
| Registered Join Date: Jun 2009 Location: Santa Fe, NM
			It should just pop and get bigger with more air. Add more and see what happens!
				__________________ Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." | ||
|  09-16-2011, 08:18 PM |
| Fleabit peanut monkey |
			If it is an emergency spare they can look odd compared to a regular tire. Appears you have a schrader valve so it should be like filling up a bicycle tire. What is not working? Can you hear air going in? | ||
|  09-16-2011, 08:31 PM |
| Registered Join Date: May 2002 Location: Portland, Oregon
			Your spare looks odd. Do you have two schrader valves? What size is the tire? My 15" looks like the one in this picture (thanks to cpfoster):  There is a 16" one that looks like this (thanks to pordude):
				__________________ Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 09-16-2011 at 09:02 PM.. Reason: added 16" tire | ||
|  09-16-2011, 08:59 PM |
| Member 911 Anonymous |
			+1 put some more air into it, 30 lbs??? Be Warned the valve's rubber washer will get brittle over time and leak. Ask me how I know.  I simply replaced it with a standard rubber valve at my local tire shop, works perfectly.
				__________________ '85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC | ||
|  09-16-2011, 09:13 PM |
| Diss Member Join Date: Jul 2002 Location: SC - (Aiken in the 'other' SC)
 The collapsible spare for the Carreras should be inflated to 36psi. (Not sure about the later cars...) The one thing not mentioned so far... These cars came with an air compressor so you can inflate it when you need it. The important detail from the manual: - "The spare wheel may only be fitted at the front. This means that when one of the rear wheels is defective, the intact front wheel on the same side of the car must be fitted at the rear." The manual also instructs that you inflate the spare after it is mounted. (But I'm not sure why that would make a difference.)
				__________________ - "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. | ||
|  09-16-2011, 10:08 PM |
| Registered User |
			I think the question for most of us is:  If we fill it to test, will it shrink back down to fit the opening?
				__________________ Richard 1989 Venetian Blue Targa | ||
|  09-17-2011, 12:12 AM |
| Registered | Quote:
 Try filling it with a real air compressor, not the 12v weezer that came with the car.
				__________________ madmmac AKA Mitch 1984 Factory Turbo Look 2006 4Runner 1998 TRD Supercharged 4Runner (Sleeper) | ||
|  09-17-2011, 12:29 AM |
| Registered |
			Thank you guys!! Mine looks like the red one. I realized that a compressor is needed. However, I was able to fill it somewhat it with a bicycle pump, I hope I don't need to use it in today's trip and if a rear tire go out somehow this thing will have to work back there, Thanks for the help!!
|  09-17-2011, 03:17 AM |
