High beam indicator help - '84 Targa
Does anyone have any guidance to offer regarding re-alignment of a high beam indicator light lens. I assume that there is a blue lens over a hole that is back-lit by a light bulb. My lens has moved out of its original position and the light/hole is only half blue. The other half is just the light shinning through the hole. Is it possible to get to this lens and reset it? Any input would be appreciated..... Thanks!
Old 10-07-2011, 10:14 PM
RETIRED
Joe Bob's Avatar
Involves opening the gauge. The bezel is a bit tricky to remove....if you chinger it up, PA or North Hollywood Speedo can fix it.
Or you can just ignore it.
2012 ML350 3.0 Turbo Diesel
Old 10-08-2011, 06:23 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Lens.
Another source that I have used for many years:
Paul's Speedometer Shop in Redondo beach.
He does repair work for Pelican.
I would not attempt this fix on my own.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-08-2011, 09:42 AM
Okay... Thanks you guys. Off to the speedo shop it goes. It may not seem like that big a deal having the blue lens a little out of place but the car is so close to being just right that I feel compelled to correct this small issue.
Old 10-08-2011, 09:31 PM
