J-Mac's Avatar
Rtu0894 What's setup is that ?
SSIs with MK2i2o GT3 with quiet riot baffles? What engine? Any sound clips? Tx
J Mac
Current 0
Sold - 67 911T Coupe racecar, 87 911 Cabriolet, 85 911 Targa, 98 Boxster, 95 993 Coupe, 88 911 Cabriolet, 75 911 Carrera #144, modified
Old 01-24-2018, 08:00 AM
I use a 997 GT3 4.0L titanium muffler on my Fabspeed headers. Great and super light set up! And you can valve the exhaust for LOUD and INSANE LOUD options. Great for pissing off the neighbors!!!
1985 928 S3, 5-speed
1987 Carrera, current project
2012 Jaguar XF 5.0, Wife's d.d.
2009 Boxster,sold, 2000 Boxster, sold, 1995 993, sold, 2004 Maserati, sold, 2000 996, sold, 1971 914, my college car, 1966 911, sold way too cheep, Lots of VW's...
Old 01-24-2018, 09:14 AM
rtu0894's Avatar
Brian Bodart headers @ rarlyl8, gt3 style muff. When I was researching the purchase, I thought it was going to be too loud so I bought the quiet riot baffles at the same time, direct from qr's website. Installed everything at once and actually thought it was too quiet. I had the baffles in for about 2 days then sold them. Side note, I never believed they worked as described. I like the principle, but the spring pressure seemed too excessive when moved by hand to think that exhaust pressure was ever going to ' open them up'. Thought about mounting a camera to check, but never did because I thought were too quiet anyway...
Old 01-24-2018, 01:14 PM
rtu0894's Avatar
I may be in the minority though, I still don't think it's that loud without the baffles. Someday, when I have some extra coin burning a hole in my pocket, I thought of having another muffler customer made. Same gt3 external, but whatever baffles are on the inside, I want a lot less of them! If it wasn't for my respectable neighbors, I would run this stinger more often. I put it on once or twice a year for a few runs. Doesn't sound great when letting off the gas at low rpm. Similar to a Ford pinto with a leaky exhaust manifold and rusty muffler. But it's sounds like a full blown rally car above 4K. With a throttle blip between shifts, it gives me chills!
Old 01-24-2018, 01:22 PM
New set-up completely done.
GT3-style 1 in 2 out from M&K with custom exhaust tips singers style.
RS rear bumper finished with 3 mm rubber strip.
Sounds fantastic!
Old 01-31-2018, 05:31 AM
David 23's Avatar
Sounds fantastic!
Beautiful car, smooth, sleek and elegant with lovely details. Nice job. I think some video clips are in order?
1979 911SC 3.2 SS Custom Backdate Hot Rod
1972 911T, 2.7RS Spec
Beck 904 Carrera GTS /3.6
2023. Macan
Previously owned several 911 models since 1975.
Old 01-31-2018, 06:25 AM
Location: behind the redwood curtain, (humboldt county) california
Civilized "megaphone" Tips
I tried to find the thread for the "sport" conversion, but all I could find was this photo I squirreled away.
I really like the megaphone tips, wonder what it sounds like??
Anyone remember this thread??
chris
PIPES, Wait till them kids in the chevys see those pipes
Old 02-02-2018, 11:52 AM
2 Out Muffler
1985 M491 with 70's style dual outlet muffler. M & K Pre Muffler (replacing CAT). Runs and sounds great. No drone.
Old 02-02-2018, 02:05 PM
911bruce's Avatar
Would love a set up like that but in good old California I have to run a CAT still, grrrrr. Does anyone make a set up that incorporates that?
Old 02-02-2018, 07:27 PM
86FlatSix
JQ911's Avatar
You mean this? I have the original cat on the 1 in 2 out GT3 style
74 BMW 2002 (rust rocket)
86 911 Coupe (weekend warrior)
09 997.2 C2 (semi-daily)
Old 02-02-2018, 08:22 PM
Registered Minimalist
75 911s's Avatar
Sport conversion from Up Fixin' / pano
Did the old school conversion following the Up Fixin' der Porsche vol. IV article from an old Panorama.
First I started with a rough mockup to see if I would even like two out. Also moved the tubes around to see if I wanted GT3, rally or other spacing.
I thought it would be cool to center them perfectly under the license plate so that, If I wanted, I could put the original US bumperettes back on and the tips would clear them.
Here's my original muffler. It's a 2 in with an EGR bung. I had the hole welded shut when I did the rest of the mods.
The original one out hole with new flat cap welded on.
Showing the internal mods. Essentially two cut holes. The left side becomes a nearly direct pass through.
I had short tips put on because I had always planned to put the original Porsche black stock tips on. They proved too difficult to size and affix.
I ended up buying these fleabay 904 style cookie cutter tips.
I also had to reweld the right exit. The Up Fixin' article doesn't give exact measurements. The odd thing is, the dual outs don't seem to be centered on the muffler itself. The right out is closer, to the mount strap. Since I had the muffler off the car when I did the original mod, the dual outs were not centered exactly and it drove me crazy. After I had it fixed, I covered in high temp bbq white.
[img]http://forums.pelicanparts.com/uploads26/whi****ff1517667086.jpg[/img]
It drones at 2k but "Seat of the pants" dyno on my custom 2 out is a huge improvement. I bought a motorcycle baffle for the left out as it was more direct and I felt an immediate nerf of the power. So I took it out.
The sound is really really fun. A downshift to 4th on the freeway for a hard pull and shift back to 5th is glorious. Tunnels are my favorite.
The downside is being a dude with loud exhaust. The upside is really hearing every gear change and rpm.
I also have a one out Bursch muffler and seat of the pants dyno blows it away. Whenever I mount the Bursch, I miss hearing the car.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 02-03-2018, 06:41 AM
