Rotor for MSD Ignition
I read through the 3 page thread on melting rotor when used with MSD but could not follow which would be the best choice for my application.
I've got Bosch dizzy 0-231-169-008 from a 73.5 911T with a Petronix ignitor and MSD ignition and Magnecore wires. I'd prefer a reference to a Bosch part that does not require alteration (if that exists/912 rotor?). I don't want the crap shoot with NAPA unless of course that is the only option for a 911T application. Thanks for the help! Kev |
Anybody? I want to place an order here on Pelican for the correct rotor today so it will go out tomorrow if possible.
Kev |
I think some of the old VW rotors are a solid non resisted type. Look into them , I do not remember the years. 70s ?
I bought the one at NAPA, works great.
get brass contacts, they last much longer than Alum.
oh yeah, I burned a rotor because "someone" "Young and dumb" put never-seize on plug threads,[no , or little ground contact]!!!!just a drop of oil! and keep stuff out of plug holes, I have vacuumed plugs before pulling.
I use Bosch
Bos-04038
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
I never had a problem with the Bosch one from PP... I kept using the stock rotor and distributor cap
David 1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit 1981 Black 911sc (sold) |
Buy the Napa EP407. $3.99 each....Works just fine...
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
I see comments about using the Bosch rotor from PP but I don't even see one listed here that isn't RPM limiting for a 911T. We talking about the correct engine application?
pelican has sold me a bunch of them over the years
they up-graded their pn to 055-905-225B-M5014 in May 2010 I paid $6/ea
