Certified User
How to test a 6 pin CDI ?
I am trying to track down some electrical gremlins in my '86 930 which has the Bosch 6-pin CDI (same as earier 3.0 litre SC's).
My 930 shop manual has some sketchy instructions for testing an 8-pin unit, but what I really need is a set of test specs for the Bosch 6-pin unit along the lines of the equivalent PermaTune CDI unit below (taken from their website).
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S |
if it is randomly cutting off, you need to figure out if it is ignition or fuel. when it is not running, check ignition. keep a spare plug handy to make it quick.
for ignition, usually random dieing is the result of heat and about the only way to fix it is to what for it die completely (sucks) or swap CD, coil and possibly dist. (one at a time) for fuel, look for fuel pumps, relays and dont forget the speed sensor. you can go here for my explanation of the fuel circuit http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/615670-fuel-pumps-not-working-ign.html i hope this helps
Since it's always good to have a spare CDI unit, why not buy one from a wrecked-em yard?
There are peole here stateside who rebuild them. Maybe somebody in OZ does the same?
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Bill,
Check the front fuse panel. I was suffering with the same problem a few years ago and went round and round trying to track it down. I found the long fuse block had broken in half. The break was difficult to see because it was hidden by the fuses. I guess over time the plastic just gives up and can crack and become a source of intermittent electrical problems.
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
Certified User
Still looking for test specs. Surely someone knows how to test one of these
The Porsche service manuals serve as a good starting point. I also have developed a good CDI / ignition troubleshooting guide fro my '87 930.
Send me an email..
Thank you, HFR_Racer '87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups. |
ROW '78 911 Targa
Interesting thread here:
http://forums.pelicanparts.com/porsche-911-technical-forum/203100-6-pin-sc-turbo-cdi-unit-repair-documentation.html
Stranger on the Internet
Search and use Early_S_Man as a criteria. Warren had lots of stuff on the 3 and 6 pin boxes.
OOPS! Link above by timmy2 goes right to the thread I was thinking of!
Patrick E. Keefe 78 SC Last edited by patkeefe; 02-16-2012 at 05:13 AM.. Reason: Poor preparation prior to posting. |
Certified User
Thanks for the input guys. I now have a heap of stuff to work though on the weekend!
ecu
i used SPECIALIZED ECU REPAIR out of Florida they have a core and a 5 yr warranty. They are customer friendly and may educate you on the testing as well as replacement options.
