Brake Booster Failing???
Hello all, I have a 79 sc. I have recently had a problem where my brakes would not release. If i stick my right foot under the back of the pedal it will return to normal until I press the pedal again and then I can continue doing that as long as I need. I just dont enjoy driving like that so would like to fix it. I rebuilt the front calipers and bleed the whole system using a Motiv Power Bleeder. I have since bleed the brakes twice and it has gotten better but still doesnt go all the way. Any thoughts would be appreciated
Thanks Brandon |
Not sure about the booster, but I wouldn't rule out the pedal cluster / spring either.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Ditto on the peddle assembly not the booster.
83 SC |
