Been There Done That
Targa Latch Ideas??
Hello all,
From what I can gather targa tops and latches and frames are hard to come by. I dont even see a replacement latch for my top available and the ones I did see was a set for around 500.00. Anyway, my question is this, one of my latches is broken and I was wondering if anyone came up with a clever solution to fix it? I have included a picture and it seems like two parts of it have broken off but im not hundred percent sure on that.. this is on my 77 Targa.
thanks
Old 03-21-2012, 12:55 PM
72T 72T is offline
If our host doesn't have anything that will fit your bill, you could check a used parts house, there are many. You could probably cold weld that back together, but I'm not sure I'd trust it. If you think the latch is broken, best replace it so as to insure against the top going air born when you are at speed.
Old 03-21-2012, 01:16 PM
Je Ne Sais Quoi = Targa
Mikey83835's Avatar
I bought one from this guy and am waiting for it, and as of last week he still had the other latch for sale,
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/665384-parting-out-1984-911-targa-g50.html
But a question also, how did you get the L-shaped vinyl cover off, is it glued on and you just have to force it off and then reglue it.....or?
'74 Targa lightweight widebody, 3.6 motor, big bars, Speedlines, Sold 2018,
'81 SC Targa with 3.2 spoilers, Webers, SSIs, 7&8X16 Fuchs, 911R style exhaust,
Had a '71 911S Targa in the 80's, miss it,
Had a '61 Roadster in the 70's, miss it also,
Old 03-21-2012, 01:22 PM
the metal is thin and almost like pot metal im not sure a weld would do it
Old 03-21-2012, 01:36 PM
Thanks for the tip.
My L pad was trashed so I was not so delicate with the removal.. but it appears to be glued and attached with body fasteners..ive attached a pic for you to look at.
Old 03-21-2012, 01:46 PM
Your handle is toast (post a WTB to get another one). A replacment for the broken part of your latch is available. Paste SIC-565-032-00 in your browser.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 03-21-2012, 01:52 PM
Brian
Thanks Brian!!! that helps alot!
Old 03-21-2012, 01:59 PM
scottb's Avatar
A good source of Targa top info is Dan Pechtel. Targa Tops for Porsche
1984 Targa
Old 03-21-2012, 03:34 PM
I had both eares of one of my latches break off. I drilled a hole into the remaining piece of the mechanism and JB welded a piece of allen wrench in the hole. You can then open and close the latch with a socket wrench. It's also a good idea to press down on the top at the latch location when opening and closing the latch. It relieves a little friction while the mechanism is opening and closing relieving the stress on the ears where the handle fits into the latch.
I have since replaced the latch with an unbroken one but keep it just incase I need a back up.
Old 03-21-2012, 06:01 PM
Hello all, based on the good advice I found the replacement part for the latch. however now that I have it I cant figure out how this latch comes apart and I dont want to break it. Is this part just pressed in? anyone know?
thanks
Old 04-01-2012, 12:54 PM
forgot the pic..
Old 04-01-2012, 12:55 PM
It seems to me a quick hacker fix might be JB weld and a small hose clamp
1979 911 SC Targa
http://www.pelicanparts.com/gallery/Mike_Kast
Old 04-01-2012, 02:29 PM
KCinBR's Avatar
Your best answer lies with Dan Pechtel
KC
88 Guards Red Targa (sadly sold )
2005 Boxster S
1st Porsche 73 914 (long gone)
Old 04-01-2012, 02:37 PM
I have been living with a ****ty roof for 10 years. In my opinion, either blow the mother load and get the 800 dollar rebuild or do the hacker repair until you can. The reason being, you can spend a lot of money on parts on a ****ty roof and still have a ****ty roof. This isn't a concourse inspected item, it is a matter of function.
On the other hand, if your roof is in great shape besides this issue, spend a bunch of time and money.
1979 911 SC Targa
Old 04-01-2012, 02:45 PM
I know this is a fairly old post....but what did you have to do to tear into the latch?
Old 01-19-2013, 06:03 PM
