TJM Carguy's Avatar
Send a message via AIM to TJM Carguy
How important? (Rear suspension bushings)
Hi,
Getting ready to replace front sway bar drop-link bushings and rear springplate bushings. My question is; Should I replace the bannana arm bushings in the rear while I have the rear suspension taken apart? How important is it to get them replaced?
-TJM Carguy
http://www.angelfire.com/mi2/tylermerkel
Old 04-27-2002, 11:21 AM
Navin Johnson
TimT's Avatar
you might as well replace them, after all they are the same age as the other bushings, and have seen exactly the same amount of use/cycles etc.
If in doubt drop one of the banana arms, and have a look at the bushing..if the rubber is cracked or distorted time for replacement
'69 911 GT-5
'75 914 GT-3
and others
Old 04-27-2002, 04:46 PM
marcesq's Avatar
TJM:
Replace with rubber bushings, not plastic unless the car is primarily tracked. The plastic bushing do not allow the control arms to move in 3 dimemsions and are quite harsh.
Others will have a different opinion, so you might want to search previous threads to get the whole story.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 04-27-2002, 06:15 PM
