79 911SC Exhaust Upgrade Suggestions
Hi All,
I'm finally getting around to spending the time and $$ to improve my 79 911 targa. The original exhaust is getting pretty tired so I'm embarking on a fairly full rebuild.
I am planning on the SSI heat exchangers, and probably a Dansk factory-style muffler.
Issues: The catalytic converter is very rusty and I'm sure ready to be replaced as well. I live in Washington State (Seattle) and after 25 years the cars are no longer subject to emissions testing so:
Question one: do i replace the catalytic converter with a straight pipe? How will that affect performance? Will the car need further modifications to air/fuel mixture? Does a straight pipe significantly change the sound? (I want to keep the car mostly stock.)
Question two: what other mufflers would people suggest?
Thank you!
Old 04-02-2012, 03:33 PM
Flat Six
Flat Six's Avatar
Your as-planned SSIs attach directly to a 2-inlet muffler; no provision for retaining/bypassing cat. Moot question.
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 04-02-2012, 03:49 PM
Oh Haha's Avatar
Originally Posted by flat six View Post
your as-planned ssis attach directly to a 2-inlet muffler; no provision for retaining/bypassing cat. Moot question.
+1
Pacific Blue
Wayne
Old 04-02-2012, 04:21 PM
Chief Head Scratcher
kerthunk's Avatar
You kind of have an either/or thing here.
1. SSIs with a new 2-in 1-out muffler
2. Cat bypass pipe and current (or new) 1-in 1-out muffler
If you are changing to SSIs, you may need to tweak your AFR mix slightly but you should gain some HP. The cat bypass won't net you much gains unless your current cat is clogged up.
The Dansk Sports are a good choice as well as an M&K. Monty makes some nice ones as well but seem much harder to find.
I'm over on Bainbridge Island. Feel free to shoot me a PM if you want to get together and talk about car stuff.
John Morris
'79 911SC
Old 04-02-2012, 04:39 PM
vote for ssi's and M&K but biased
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 04-02-2012, 05:28 PM
kerthunk's Avatar
That's the choice that I made! Ben, you do some great work!
jsedlock, the SSI upgrade is definitely a good thing. But if you are planning on doing the swap yourself, there are a few potential gotchas like broken exhaust studs and such that can make the project much more daunting. Bolting in a new cat bypass is a walk in the park. Worst case is all your fasteners are rusted solid, just get a nut cracker and new stainless hardware.
John Morris
'79 911SC
Old 04-02-2012, 06:01 PM
As others have said, the SSI's into a 2-inlet muffler deletes the catalytic converter, as it is a stainless steel replica of the pre-75 (pre emissions) exhaust. Here is a pic of mine to demonstrate that there are no cats.
As for myself, I have a Dansk 2in/1out muffler factory replacement muffler, and highly recommend it. Secondly, I'd have an M&K 2in/1out as it is lighter than the Dansk and doesn't have the drone issues associated with dual outlet mufflers.
The exhaust upgrade is incredible. Not only does it sound incredible, but it looks fantastic (for those nerdy enough to look), the mid-range torque is vastly improved, the top end horsepower bump is great, and the improvement in cabin heat is much appreciated.
Old 04-03-2012, 04:54 AM
SC Ray
81 SC Ray's Avatar
I agree with Will. Think long and hard before you go with a two out exhaust.....the sound is really awesome....for a few minutes. But, I do not track my car. So, for me, "the drone" is not a good thing - it is just annoying over time. But, the SSI's into a 2 in - 1 out muffler is the best of both worlds. You don't need your radio, car "guys" look to see what is making that cool sound and you can cruise on the highway with no regrets.
Ray
Old 04-03-2012, 05:30 AM
Limbo
Slider79SC's Avatar
If you are going to pull your exhaust to bolt on SSI's, start spraying your exhaust nuts daily for a week or so with something like Kroil or equivalent to saturate them and try to prevent breaking them during removal.
I did this and had no issues.
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 04-03-2012, 06:58 AM
thanks to all!
Fantastic responses. I'm feeling more confident than ever. I replaced a 70 corvette exhaust once and indeed, soaked the fasteners for a few weeks before proceeding.
Thanks to all for taking the time to reply.
Old 04-03-2012, 01:43 PM
Hi John,
Thanks for the reply. I'd like to talk to you about this: obviously if i thought I still needed a Cat I must have missed something in my research. I read several articles re: SSI exchangers and never did it say "scrap your cat." I'd be pleased to chat. I'm just getting back into putting my car back together. New passenger side window lift motor this weekend, now replacing the door speakers since it's apart (and the rear deck speakers, what the heck?) but the exhaust is looming. Also planning on doing my front wheel bearings soon (slight groan once in a while) and bleeding brakes.
fortunately the exhaust was off the car about 10 years ago (and probably 2000 miles only) so hoping the studs are cooperative. Let's chat!
Old 04-03-2012, 01:49 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
+1 on spraying ur nuts.
SSI's and monty 2in/2out. hard to find used. one out is an option but sounds different.
if u dont wanna wait to find a monty go M&K.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 04-03-2012, 03:33 PM
PorscheNerd's Avatar
Fabspeed makes some seriously nice exhaust setups. All stainless...
Porsche Nerd
1976 Targa
2012 VW TDi SportWagen
2012 Volvo C30
Pittsburgh, PA
Old 04-03-2012, 05:26 PM
