Jupiter 911
bklyn's Avatar
Gauge bulbs, how do I remove?
Trying to remove my speedo on my 87 Targa to access the bulbs. What is the best way to remove the gauge and how do those tiny bulbs come out. Thanks Lenny
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 04-14-2012, 05:17 AM
The gauges just pull out.
1983 911SC Varioram
O #19
Old 04-14-2012, 05:25 AM
I was able to pull mine out with just my fingers. The light bulb sockets will also pull straight out. Be careful not to pull on the wires to much when you pull the speedo out.
'86 Carrera Cabriolet Grand Prix White
'09 VW Beetle Convertible
‘24 Audi Q8 etron
Old 04-14-2012, 05:34 AM
Mitch Leland's Avatar
Gauge removal...
Lenny, sometimes one instrument will be easier to remove than another. So if the speedo doesn't want to pull out, then try for another instrument. Once one of the instruments is out, then you can go behind the instrument panel and push the speedo. The only thing that holds the instruments in place is the rubber seal/gasket.
Like has already been said the light sockets should snap out. I would suggest rocking the socket back and forth rather than just pulling directly on the socket. If you completely remove one of the instruments, be sure to mark the wires so everything goes back together correctly.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 04-14-2012, 09:09 AM
