its that time for a new set of spark plug wires any suggestions?
86 911 3.2 mostly a daily driver its time to change the spark plug wires any suggestions?
1966 912 with 2.2 911 motor 1986 wide body 911 1995 993 Polar Silver |
A set of Clewett from our host are fine.
I have Clewett wires on both of my 3.0's and they have held up well. Good fit and price is reasonable and agree buy from our host.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Like they said.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
what about the beru wires?
76 911S Targa
I bought Magnecors from our host. They also work well. I had OEM Beru wires with the braided metal sheath. They were old so I do not fault them but they gave quite a light show in the engine compartment. If your current ignition wires are old, as in 26 years old, you might do the visual test in total darkness with the engine running and the engine lid open. Just see if there are any light shows playing in your engine compartment. I think any of the wires mentioned in this thread are good if they are new, Clewitt, Beru or Magnecor. Some people on this forum buy the ignition cable in bulk and fit proper ends on them. That is supposed to be cheaper. I believe I read that the old cable ends, if undamaged, can be reused with new ignition cable.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
how about DIY and do it with bigger size? Is bigger better?
Fat butt 911, 1987 |
any ideas
so bigger wires? what brand?
I am throwing up a question to see if any response. On other cars I had, many get bigger wire and claimed better performance.
SC Ray
Beru's - perfect fit, perfect look, perfect performance - after all, how long have the ones you got lasted.................
Ray |
i bought this motor with 62k on it. they have been sitting around for awhile so i guess if they are original 26yrs ill take a pic of them when i get home
I changed out to some red Magnecores from the host last fall and they work fine.
I just put red Magnecors (as well as a cap and rotor) in my '86 this past weekend. I finished on Sunday and it was raining, so I haven't even had a chance to drive the car since.
Purely from an installation standpoint, the Magnecors are a minor PITA. First, if you want to reuse the OEM wire holders, you'll need to drill them because the Magnecors are thickets. This was easy. The part I didn't like was that the lengths on the wires weren't quite right. A couple were just right, a couple were a bit too short and a couple were a bit too long. I made them work but it made routing them more difficult that it should have been.
1986 911 Carrera Coupe 2016 VW Golf R 2008 Toyota Highlander (given to kid) 2021 Kia Telluride 2020 BMW R1250RS |
KV85 Magnecors
Ole Skool - wouldn't have it any other way |
I just put the Beru's in last weekend. My decision was based on aesthetics as I liked the stock look of the black wires, wire covers, spacers, and brackets. And my old plastic bits were cracking into pieces.
Installation took a while as I learned that the AC compressor had to come out to route them in the factory location with stock brackets. But everything fit perfect since I was replacing with the identical wire. Last edited by DWeg1998; 04-24-2012 at 08:53 PM.. |
I have Magnecors on mine...
1986 911 Targa We affirm that the world’s magnificence has been enriched by a new beauty: the beauty of speed. A racing car whose hood is adorned with great pipes, like serpents of explosive breath - a roaring car that seems to ride on grapeshot.... |
i think i am leaning towards beru. i did the light test i see a little light show
Just make sure you use the wire holders and do not cross-wire them out of firing sequence.
