kinein's Avatar
Send a message via Yahoo to kinein
its that time for a new set of spark plug wires any suggestions?
86 911 3.2 mostly a daily driver its time to change the spark plug wires any suggestions?
1966 912 with 2.2 911 motor
1986 wide body 911
1995 993 Polar Silver
Old 04-24-2012, 12:54 PM
poorshe911's Avatar
A set of Clewett from our host are fine.
Old 04-24-2012, 01:36 PM
rfuerst911sc's Avatar
I have Clewett wires on both of my 3.0's and they have held up well. Good fit and price is reasonable and agree buy from our host.
Old 04-24-2012, 02:18 PM
kodioneill's Avatar
Like they said.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 04-24-2012, 02:43 PM
kinein's Avatar
what about the beru wires?
1986 wide body 911
Old 04-24-2012, 02:47 PM
76 911S Targa
I bought Magnecors from our host. They also work well. I had OEM Beru wires with the braided metal sheath. They were old so I do not fault them but they gave quite a light show in the engine compartment. If your current ignition wires are old, as in 26 years old, you might do the visual test in total darkness with the engine running and the engine lid open. Just see if there are any light shows playing in your engine compartment. I think any of the wires mentioned in this thread are good if they are new, Clewitt, Beru or Magnecor. Some people on this forum buy the ignition cable in bulk and fit proper ends on them. That is supposed to be cheaper. I believe I read that the old cable ends, if undamaged, can be reused with new ignition cable.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 04-24-2012, 03:03 PM
kinein's Avatar
i rather plug and play. i am goin to do the light test tonite see if i get a light show they are old
1986 wide body 911
Old 04-24-2012, 03:09 PM
rnln's Avatar
how about DIY and do it with bigger size? Is bigger better?
Fat butt 911, 1987
Old 04-24-2012, 03:12 PM
kinein's Avatar
any ideas
1986 wide body 911
Old 04-24-2012, 03:37 PM
kinein's Avatar
so bigger wires? what brand?
1986 wide body 911
Old 04-24-2012, 03:47 PM
rnln's Avatar
I am throwing up a question to see if any response. On other cars I had, many get bigger wire and claimed better performance.
Fat butt 911, 1987
Old 04-24-2012, 04:12 PM
SC Ray
81 SC Ray's Avatar
Beru's - perfect fit, perfect look, perfect performance - after all, how long have the ones you got lasted.................
Ray
Old 04-24-2012, 04:14 PM
kinein's Avatar
i bought this motor with 62k on it. they have been sitting around for awhile so i guess if they are original 26yrs ill take a pic of them when i get home
1986 wide body 911
Old 04-24-2012, 04:45 PM
I changed out to some red Magnecores from the host last fall and they work fine.
Old 04-24-2012, 06:15 PM
I just put red Magnecors (as well as a cap and rotor) in my '86 this past weekend. I finished on Sunday and it was raining, so I haven't even had a chance to drive the car since.
Purely from an installation standpoint, the Magnecors are a minor PITA. First, if you want to reuse the OEM wire holders, you'll need to drill them because the Magnecors are thickets. This was easy. The part I didn't like was that the lengths on the wires weren't quite right. A couple were just right, a couple were a bit too short and a couple were a bit too long. I made them work but it made routing them more difficult that it should have been.
1986 911 Carrera Coupe
2016 VW Golf R
2008 Toyota Highlander (given to kid)
2021 Kia Telluride
2020 BMW R1250RS
Old 04-24-2012, 06:41 PM
KV85 Magnecors
Old 04-24-2012, 07:06 PM
DWeg1998's Avatar
I just put the Beru's in last weekend. My decision was based on aesthetics as I liked the stock look of the black wires, wire covers, spacers, and brackets. And my old plastic bits were cracking into pieces.
Installation took a while as I learned that the AC compressor had to come out to route them in the factory location with stock brackets. But everything fit perfect since I was replacing with the identical wire.
Old 04-24-2012, 08:50 PM
Hydrocket's Avatar
I have Magnecors on mine...
1986 911 Targa We affirm that the world’s magnificence has been enriched by a new beauty: the beauty of speed. A racing car whose hood is adorned with great pipes, like serpents of explosive breath - a roaring car that seems to ride on grapeshot....
Old 04-24-2012, 08:53 PM
kinein's Avatar
i think i am leaning towards beru. i did the light test i see a little light show
1986 wide body 911
Old 04-24-2012, 09:13 PM
Just make sure you use the wire holders and do not cross-wire them out of firing sequence.
Old 04-24-2012, 09:23 PM
