1986 911/Targa
Can't shut my door! Help
I was trying to fix the window switch, and I got curious with the door latch. I turned it, now I can't turn it back. Used the key to unlock it won't even budge. What to do. By the way. I fixed the window. It now goes up and down. Thanks guys.
Also, there is a place to,put the key right on the side of the door, what is that use for? |
Is the door open or closed? If you can, try opening it with the INSIDE door handle.
The "other" key is typically for an alarm. If you have never used it, it's probably defunct.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Fleabit peanut monkey
I just twisted mine to replicate. It locked. I squeezed the outside door handle lever and it released.
I did the exact same thing once. First I freaked out. Then I tried the handles and one of them released it - can't recall if it was the inside or outside handle, but all was well after that. Decided not to do that again...
muck-raker
squeeze the handle and manipulate the door latch back to its original position.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
1986 911/Targa
I did it. this one was not easy for me. I did what Mr. Bob contact suggested. Thanks guys.
Enthusiast
I did this the other day and almost freaked out until I realized the outside handle releases it - scary moment.
Jonathon 1982 911 SC www.avrmotorsports.com |
You might be due to lube up your door mechanisms. Just sayin.
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo |
kidrock has the real answer if there was a problem - lube or spring issue. Coax it back into place while pulling the handle then get your fixin' on. |
Member 911 Anonymous
+1 what Bob wrote, I do this all he time to make sure all is working well with both doors.
![]() No worries.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
