WPOZZZ's Avatar
Originally Posted by JJ 911SC View Post
Just missing the tires...
7 x 17: 16.5 Lb
9 x 17: 18 Lb
How's the quality of the paint and clearcoat, fit & finish?
Old 06-23-2012, 08:50 PM
83 911 Production Cab #10
JJ 911SC's Avatar
As per previous comments, it has ridge as opposed to smooth polished. The paint/coating look fine. The photo was taken with an iPhone 4 at less than 2 feet.
It's all about expectation, my set was $723 so it can not be compare to 2K+ sets.
They look very good.
Who Will Live... Will See
Old 06-24-2012, 03:25 AM
Banned
7 x 17: 16.5 Lb
9 x 17: 18 Lb
That's actually not too bad for a cast 17" wheel.
Old 06-24-2012, 07:06 PM
The wheels are very well designed, but fit and finish is not amazing. The 9s are not bad in spite of some minor imperfections in the paint around the hub, but both the 7s had defects in the finish of the valve stem hole, one of which is particularly sloppy and will need to be replaced. Overall, a good value, but quality control could be a lot better.
Old 06-25-2012, 10:36 PM
WPOZZZ's Avatar
Any markings on the rim to show where it was made?
Old 06-25-2012, 11:02 PM
There is a "Made in China" sticker.
Old 06-25-2012, 11:16 PM
WPOZZZ's Avatar
Did you check runout on the wheels? I had the Rota Fox and man the runout was crap.
Old 06-26-2012, 12:46 AM
I have not, but hopefully that won't be an issue.
Old 06-26-2012, 11:13 PM
Rescuer of old cars
Arne2's Avatar
My comments from the other Eurmeister thread:
Originally Posted by Arne2 View Post
IIRC, the Linea Corse/Rota Fox are gravity cast wheels, while I believe (having read somewhere, I think) that the Euromeisters are low-pressure cast. Speaking from 20+ years experience in wheels/tires (prior career), the low-pressure cast wheel should be somewhat superior structurally.
That said, either should be OK for normal street (or even mild track) use. The runout issues reported by Rota buyers is a larger issue in my mind. I'll be curious to hear the the runout specs on the Euromeisters once the first buyers start having tires mounted. But I really don't expect to hear many problems on that. The reality is that many of the Chinese wheel manufacturers do a very good job on that score.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 06-27-2012, 08:18 AM
JJ 911SC's Avatar
The Marking
One per Petal...
Old 06-28-2012, 06:18 PM
JJ 911SC's Avatar
Finish Product...
Amazing what a $9 spray paint can will do. The center and lug nut were black
Front 7x17 Et 23 (16.5 Lb), 80mm spacer/adapter combo with 205/50 R17
Rear 9x17 Et 15 (18 Lb), 70mm spacer/adpter combo with 255/40 R17
The tire were the same on my Cup wheel so no change size wise
Old 06-29-2012, 05:25 PM
aadrew10's Avatar
I feel like I read this somewhere before.
Old 06-29-2012, 06:00 PM
JJ 911SC's Avatar
Yes, since there is about 5 different Euromeister thread going...
Wouldn't want to leave anybody behind.
Old 06-29-2012, 06:23 PM
Rescuer of old cars
Arne2's Avatar
Yeah, too many. In the 240Z forum I still admin/moderate I would have merged them all into one.
2018 718 Cayman 2.0
Old 06-29-2012, 06:50 PM
