mobil 1 15/50 or 20/50
Purchased a 1977 911S Targa with 95,000 original miles. Came from San Deigo in 04 with 93,000 miles and has basically been tucked in a garage in Ohio.
Will get pics up soon--very clean car--no rust and should be numbers matching. Just picked up this car from a PO that has let it sit for 6 years--starting it occasionally but got scared from oil leaks---I think they over filled the oil. The oil in it has about 1500 miles. I do not want to fire it up without cleaning the fuel tank and lines and changing oil. Is it ok to pull the sending unit on top of the tank and siphon the gas out this way? How would I go about clearing out the old fuel from all the lines without pushing crap through injectors or should I just use some Techron in tank with new gas and run it through? Was told car was driven from Michigan to Ohio and parked. Did this recently with 928 and smoothed out after only 5 minutes--it sat for same time--bought both. The motor has had the reactors removed, valve covers done, valve adjustment done in last 2,000 miles, Carrera Oil cooler installed and a cover over the filter installed. Some oil lines were also replaced. So, do I run the 15/50 or 20/50. Does cost make a difference--yes, but not at the expense of a rebuild. My thought is the 15/20 would not matter since it will not see days below 45/50* F. and would need the 50 for heat protection. Is the zinc need compatible in both? How do you tell if the tensioners were upgraded? Is this strictly an R&R to check? This site has provided a great deal of help getting the shark on the road-now time for the Targa to find some wind. |
brad penn or valvoline VR1. not mobil 1
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Rescuer of old cars
PO of my car used Mobil 1, I've switched to Brad Penn. If you plan to stick with Mobil 1, I've heard that the 20W-50 has more ZDDP than the 15W-50. But I can't confirm that of my own knowledge.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
There is nothing wrong w/ M1, many of us use it w/o issue and have done so for decades, have they changed the formula in that time, yes, but it is still a fine oil
Mobil oil info there are many different lines of Mobil oil, I use the 15w/50 listed second from the bottom on pg1 above, there are some that prefer the V-Twin 20w/50 listed 3rd from the bottom on pg2 because it has more ZDDP, it is a lot more expensive and the additional ZDDP is not necessary. Avoid the 0w/50 listed last it is a racing oil and will need to be changed very frequently, Avoid any ACEA A1/B1-08 rated oil Porsche recommends M1 5w/50 listed 4 from the bottom for all Porsches ever made, but I'll stick w/ 15w/50 Nothing wrong w/ Brad Penn or any of the other boutique oils except cost and availability
'90C4 |
I picked up my '86 Cab in January. The PO used Mobile 1 15W50 Synthetic oil and I kept using it. After the first 6K Miles I had to add a quart of oil. My car does not leak and the oil pressure is stable. I have driven it at temperatures in the high 20s as well as close to 100F and the oil pressure is very stable.
As far as draining your gas tank. If you lift up your car to get to the bottom of the fuel tank you can disconnect the fuel line going to the fuel pump and let the fuel drain out. I believe there is also a filter down there, but I'm not sure. Juergen
'86 Carrera Cabriolet Grand Prix White '09 VW Beetle Convertible ‘24 Audi Q8 etron |
D. |
Mobil 1
Porsche puts Mobil 1 in their new $100,000-$500,000 cars. Do you really think they would put in inferior oil in their super cars? No. They want their cars to be the best most reliable sports cars in the world. And they are.
Old <> new.
Heard of flat tappets?
'90C4 |
Banned
Fully-synthetic oil for the modern Porsche motor is a no-brainer. But it might not have enough ZDDP for our cars, so might not be the best choice. M1 is a good brand, and if you can get the proper viscosity and the proper additives, I say go for it. |
Oils again?? All I can say is I've used 15-50w Mobil 1 in my Porsches for over 30 years in Texas heat, in Turbos and normally aspirated, MFI and electronic and I have NEVER had an oil related problem.
There may be other oils out there that are equally good but you will not go wrong with 15-50w Mobil 1, and it has sufficient ZDDP. I think it is preferable to drain the tank at the bottom outlet and clean the filter there at the same time. That way the crap at the bottom of the tank will be flushed out. When it's empty I'd take the float out and shine a light down to see the condition of the tank. It would also be advisable to change out all your fuel hose and brake hoses too.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Mobil 1
All I know is if you track your car I would use VR1 or another quality racing oil. On every car I used on the track I noticed oil pressure drop off after a session with Mobil 1 oil. After switching my oil and taking my car back to the same track my oil pressure stayed more consistent and was highter overall. (the same weight oil was used for both brands) It almost seemed like Mobil 1 was breaking down with the rigors of racing. Maybe because it has less ZDDP then the racing oils? Either way I don't like to play games with oil pressure so no more Mobil 1 for me....
The current M1 15/50 offering is nothing like the older API/SG stuff and for that reason, we recommend the V-Twin 20w-50 oil for owners with air-cooled engines who wish to use an M1 product. Its good stuff.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Banned
Thanks. |
If the new cars were the same as the old cars... we wouldnt have a standing debate. would we....
You need high mileage mobil 1... its got plenty of the goo.
JP '76 911s Ice Green Metallic bone stock |
I changed to Mobil 1 on my 20 yr old motor (at the time) and it sprung leaks from everywhere! I switched away from synthetic and back to VR-1 and most of the leaks went away. I would not recommend synthetic in an old air cooled motor.
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
Unless otherwise requested, Mike Callas at Rennsport only fills with his engines with RP.
Rotella Dino ?
If I choose to stay away from synthetics given the age on the motor, which Rotella makes since---15/40 Deisel?
-Andy
72 Carrera RS replica, Spec 911 racer |
