Intermitent tach
1977 911 I think I read a repair for this problem but i cant seem to find it. My tach is usually at zero then suddenly works perfect. If i lightly tap the glass when the tach is working the needle drops like a stone back to zero....I'm thinking its more of a mechanical issue than electrical....any help would be greatly appreciated.
1977 911 Widebody 1974 340 Duster 1981 Yamaha 550 2010 750 Teryx 2005 Ford 350 SuperDuty |
Fleabit peanut monkey
I have that issue as well. New V-reg a few years back fixed the bounciness in the needle but occasionally it will just die and a hard tap on the glass with my finger brings it back to life (half the time).
Most reading I have done suggests pushing tach out (into cabin) from inside the front trunk - I think you can snake your hand in by the brake booster. Clean and/or re-seat the connections. The transmission signal generator unit is a puck type thing on the side of the trans. Not sure if that would be the issue (or even a culprit) since you (we) can tap on the tach and make things change. Here is a link about cold solder joints inside the tach itself. http://forums.pelicanparts.com/porsche-911-technical-forum/366603-tach-dies-when-hot-why.html
1981 911SC Targa Last edited by Bob Kontak; 09-07-2012 at 07:27 AM.. |
Designer King
Aside from the above mechanical and electrical items make sure your points are OK. Points that are old and not opening wide enough can cause the tach to go carazy.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
