Failed Smog Check
I took my 1988 3.2 Carrera over for a smog check today, failed, and I am suspicious of the results. On a pre-test I got HC and CO readings of:
HC (PPM) CO (%)
MAX AVE MEAS MAX AVE MEAS
85 28 20 0.54 0.12 0.09 15 mph
67 23 9 0.45 0.10 0.14 25 mph
All of which pass with flying colors. Then they immediately did an official test and I got this:
HC (PPM) CO (%)
85 28 .85 0.54 0.12 2.18 15 mph
67 23 16 0.45 0.10 0.13 25 mph
Anyone have any idea what might cause this??? I mean from 0.09 to 2.18 and what is with the .85 reading in Hydro Carbons?
I am really not sure what to think about this...
Tom Pickett
Tom Pickett
GOTA911
1988 Carrera 3.4L
Old 09-10-2012, 07:50 PM
Capitalist and Patriot
911Freak's Avatar
Lots of good threads on Carrera failed smog
This was at a "test only" station, right?
Something fishy if the tech "immediately" tested it without any time lapsing between the tests and not tweaking anything in the car... what was the explanation from the tech?
Did you run the car hard and hot as you went in for the test? What were the conditions of the car? Tuned up, daily driven vs stored weekend driver etc.
Did the Tech adjust anything between the two tests? How much time between the 2 tests?
More info needed
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 09-10-2012, 08:00 PM
There was a couple of minutes between the tests during which time the car ideled. Temp was toward the high side of normal, the car had been run for about 30 mins before the first test. ambient temps were near 80 f.
He had no time to tweak anything and yes it was a test only station which I have gone to for several years. The car itself is driven occasionally on the street but mostly on the track. When on track it uses a bypass, and a Wong chip, a Cup sport air intake with a K&N filter.
On the street it had an OEM chip, catalytic converter, stock intake and filter.
The tech said he tested immediately after the pre-test because the car was very clean on the pre-test, and he was surprised at the result afterward--said he had not seen that before. He suggested that perhaps there was a problem with the O2 sensor, or the Mass Air Sensor...
Tom Pickett
GOTA911
1988 Carrera 3.4L
Old 09-10-2012, 08:19 PM
Considering the HC (ppm) number went from 20 to 0.85 in a matter of minutes and then back to a more expected reading, I propose something went wrong with the test machine.
This appeared to happen when the failed value went from 0.09 to 2.18, please post if you have record of values similar to this.
Have others seen 0.85 ppm in the HC ppm data location. 0.85 may not even be a reading the machine can correctly measure.
Sold: 1989 3.2 coupe, 112k miles
Old 09-11-2012, 07:25 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Oil cooler fan.
Here's a thought.
If you have the 210F aftermarket thermostat:
Pull the oil cooler fan relay, drive the car, get the temp up to 230ish and try again.
This has worked for me.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-11-2012, 07:43 AM
I have not seen values like that before on my car, not the 2.18 or .85...
It has always been quite clean since I rebuilt it 3 years ago...
Tom Pickett
GOTA911
1988 Carrera 3.4L
Old 09-11-2012, 08:36 AM
I took the car back over and had it tested this morning. Results were the same as the pre-test, and it passed with flying colors. The tech suggests that perhaps something didn't work momentarily he suggests the fuel regulator, but he figures something mechanical didn't work for 100 seconds and then started working again.
Test results this morning:
HC (PPM) CO (%)
So I am left to figure out what happened...
Tom Pickett
GOTA911
1988 Carrera 3.4L
Old 09-11-2012, 10:18 AM
Possible a misfire on one of the cylinders? from heat?
Old 09-11-2012, 05:30 PM
It was running real smooth prior to testing, but then again it was running on an OEM chip and it is a 3.4 l engine that runs on a Wong chip normally...
Tom Pickett
GOTA911
1988 Carrera 3.4L
Old 09-11-2012, 07:11 PM
Tags
california smog , carrera , smog , smog check
