Anyone Know Torque Specs: Steering rack & Rear Trailing Arms
I can't seem to find the torque specifications for the following: Does anyone have these handy?
1) Steering Rack to Aluminum Cross Member 2) Rear Trailing Arms - at center bushings. Thanks in advance! |
Schleprock
'84-'88 911 spec book from Porsche says "steering gear" M10 bolt tightening torque is 47Nm = 35 lb-ft
Rear trailing arm pivots are M14 x 1.5 self locking nuts identified as "trailing arm to cross beam" 100Nm = 74 lb-ft
Kevin L '86 Carrera "Larry" |
Thank You Kevin!
