-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Wayne's Trick For Installing Muffler Straps... (http://forums.pelicanparts.com/showthread.php?t=72635)
Wayne 962 06-26-2002 11:51 AM
After trial and error on this one, I came up with a very good (and safer) way to install the muffler straps.
Problem: The straps are round, the muffler is not. You don't have enough force in your hand to squeeze them together in order to thread the *small* bolt through. Pliers and vise grips will sometimes work, but they will also slip, scratch your muffler, and will bend the straps so that you can't get the bolt through.
Solution:
Get a longer bolt with the same thread pitch:
http://forums.pelicanparts.com/uploads/bolt-1.JPG
Then thread that bolt into the muffler strap. You can simply use the longer bolt, but this one isn't stainless, and looks dopey when it's hanging out the back. Tighten down the muffler strap to it's desired level:
http://forums.pelicanparts.com/uploads/bolt-2.JPG
Then take a zip-tie and carefully wrap it around the two straps:
http://forums.pelicanparts.com/uploads/bolt-3.jpg
Now, remove the longer bolt. The zip tie should hold the muffler strap in place:
http://forums.pelicanparts.com/uploads/bolt-4.JPG
Now, you should be able to insert the shorter, stainless steel bolt with no problem:
http://forums.pelicanparts.com/uploads/bolt-5.JPG
Note, this is the method that I used *after* I injured my hand - not the one that I was trying. I was trying to simply use the zip tie to tighten the strap together (by pulling on it really tightly), when it broke. Note - you shouldn't try this - use the larger bolt to compress the strap together...
-Wayne
Superman 06-26-2002 02:55 PM
Once when I was a kid, I sat on an ant hill. Not on purpose. Red and hill. Well, moments later I was running home screaming. After removing the ants from my body, I went to the encyclopedia and pulled the K volume and the A volume. When asked what I was researching, I replied "I want to learn how to Kill Ants." Wayne, I imagine I've probably lost you again (I didn't attend MIT), but my mistakes stick to my ribs too. I guess you could say I'm focused, at times.
And on a thinly related note...I just thought of a great way to write off an engine rebuild. WRITE A BOOK.
zuerchers 06-26-2002 03:11 PM
nice band-aid!
Wayne 962 06-26-2002 03:20 PM
I'll say it again, these books are just not worth it by themselves...
-Wayne
Jim Sims 06-26-2002 03:21 PM
Oh cable ties: the bailing wire of the 21st century!:D I also a have roll of soft steel wire in my garage for the more traditional "fix" along with a dozen sizes of cable ties in white and black. Jim
RoninLB 06-26-2002 03:27 PM
I have a big bucks safety wire tool and a cheap Harbor Freight safety wire tool that cost about $8........Ron
Superman 06-26-2002 04:50 PM
Zip ties are nice, and I carry them. Some are over 2 feet long. But zip ties won't help you when you really need baling wire.
APKhaos 06-26-2002 05:50 PM
Another of life's eternal truths from Super - ROTFL, because it is SOOOO true.
There are those that know, and those that will learn soon enough.......
needlevalve 06-26-2002 06:37 PM
NICE
I must say I like those pics Wayne. Who is the bearer of that powerplant?
john70t 06-26-2002 07:26 PM
Coool Wayne, but what happened to duct tape and a really big hammer?
Wayne 962 06-26-2002 08:45 PM
That's my engine - probably going to be a display motor for a while...
-Wayne
911pcars 06-27-2002 12:31 AM
My friend the auto tech. likes to make fun of his trade. His self-deprecating repair mantra goes like this:
Hammer to shape
File to fit
Paint to match
Wayne, maybe you could add these words of wisdom at the end of the book; perhaps a chapter entitled, "When All Else Fails." :)
My feeble attempt at a little levity,
Sherwood Lee
http://members.rennlist.org/911pcars
Wayne 962 06-27-2002 12:40 AM
I've found that a Testor's model paint pen is great for touching up inevitable scratches in the paint that will occur. Especially during re-insertion into the car!
-Wayne
crater64 07-05-2010 05:09 PM
This works!
A bump to an 8-year-old + thread but just wanted to say this method works! I used it over this weekend to install new straps on my old muffler. I removed the muffler - a standard factory Bischoff 2-in, 1-out - to repaint and the original straps were pretty twisted; I didn't trust their potential longevity.
Thanks, Wayne! SmileWavy
Ed
Nine9six 07-05-2010 05:42 PM
True words, but they worked superbly in this application, no? :D
Vincent Hill 07-06-2010 09:10 AM
Wayne, two things I learned from reading this thread. #1, We all have the same problems and #2, Testors are Still In business?? I used them back in the 50's on my U Control Airplanes I flew. I think it was not Fuel Proof so I preferred Comet (At least that is what I think the other name was:) )
SpeedracerIndy 07-06-2010 10:30 AM
In 2002 when this thread was started I was just researching to buy the 911 I bought a year later. Since then, Wayne has moved on to Boxsters, 996's and to the mighty 959, yet I'm still sitting here with the same old 911. I'm in the wrong business!
Great tip. I always hate scratching up my hands trying to hold those muffler straps together for the 'not long enough' bolt.
tobluforu 07-06-2010 01:05 PM
Is this motor now in use?
Vintage914Racer 07-07-2010 12:10 PM
Great tip. I struggled with the straps a couple times and this is an easy solution.
teenerted1 07-07-2010 03:33 PM
i just threaded zip ties thru the bolt holes till they were close to the gap the bolts would take up... then did the outside zip tie trick wayne used and cut the first zips... installed bolts and drove a little to let the heat do its trick... snugged down the bolts... wow :eek: the zip ties were still there after a few weeks later... i thought it got hot back there
flash951 07-29-2010 01:56 PM
Just the tip I needed right now. Tomorrow my Dansk muffler will have straps :)
francesconyc 06-05-2024 11:53 AM
I dont understand why the author simply didn't buy longer stainless steel bolts and problem solved.
proporsche 06-05-2024 12:25 PM
Oh dear,it is obvious that you do not know Wayne the founder of this company "Pelican...parts"....??
boyt911sc 06-05-2024 03:21 PM
And Wayne D. got his engineering degree from MIT.
Tony
917_Langheck 06-05-2024 03:44 PM
Except that he did indeed buy longer bolts to address the shape of the band, which is the issue, preventing the use of the proper fastener, which is the one you want to use as it is shorter, making it easier to remove, and fractionally lighter.
So, like when installing new sping plates and bushes, use the LONGER bolt to seat the part, remove and replace with the proper bolt when it comes time to button up.
Why is that unacceptable?
PeteKz 06-07-2024 05:24 PM
Extra work.
pmax 06-07-2024 05:35 PM
Why not ?
Cause it's unnecessary weight.
