Originally Posted by BRAIDusa View Post
We can help you with the wheels LOL
I bet you can. Let me try the Vaseline trick first. I think there might be a slight cost differential.
Old 06-27-2016, 08:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5661 (permalink)
Pelican Parts Vendor
BRAIDusa's Avatar
Yes, very slight
Paul Eddleston
BRAID Wheels USA
Team Illuminata Motorsport
Old 06-27-2016, 01:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5662 (permalink)
Eva
911SauCy's Avatar
Contemplated why I would spend $$oo much on rebuilding my 3.0 when I can buy another entire car for the same cost...
And then there are the Porsche options...3.6/3.8/3.2ss
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 06-28-2016, 06:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5663 (permalink)
MARISOL78sc's Avatar
Removed INOP AC condensor and compressor.....time to lose a little weight!
Old 06-28-2016, 05:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5664 (permalink)
New tires, oil change, new clutch cable, check brake pads, grease suspension, a few other things prior to the weekend road trip.
'80 SC Targa
Avondale, Chicago, IL
Old 07-01-2016, 06:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5665 (permalink)
83 911 Production Cab #10
JJ 911SC's Avatar
Passenger Floor Board/Tray, Dead Pedal and Moch-1 Under Dash Cover. Really clean-up the under mess.
Who Will Live... Will See
Old 07-02-2016, 11:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5666 (permalink)
wayne robson's Avatar
Jack stands
Hi Otter 74, i would like to know re your jack stands,perhaps its illusion
but where do you have your stands ,are they on under your brake drum
or bracket to your lug bolts,----not criticizing just interested to know regards.
Old 07-02-2016, 04:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5667 (permalink)
911 Besitzer
I finally fixed the oil leak that has plagued me for years now! Turns out when you replace the oil pressure switch, ignore the advice not to tighten it too tight. Tighten that hummer down, because you don't want to spend a year trying to figure out what else could be leaking, only to find it's barely hand tight from being too careful the first time!
Where is the 'What did you do to your garage today' thread? I need to add 'cleaned up oil!'
1984 911 Targa
2008 BMW 128i
2007 Jeep Liberty
Old 07-02-2016, 07:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5668 (permalink)
New carpet! Mine wasn't bad but I'm a freak that way.
Old 07-02-2016, 08:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5669 (permalink)
billydeakins's Avatar
Took it for a drive to check out the ride with the newly fitted Euromeister 17x7/9's and Yokohama AD08's, then gave her a bath. Very happy with the wheels!
1989 911 Carrera 3.2, Guards Red
Old 07-02-2016, 11:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5670 (permalink)
Porsche Owner
mark4ton's Avatar
damn clean! lowered with factory suspension?
1987 Carrera - 2008 Cayenne Turbo
Old 07-03-2016, 01:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5671 (permalink)
@mark4ton - lowered to Euro height. Has Bilstein HD's on it and larger torsion bars but ride is not bad at all.
Old 07-03-2016, 08:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5672 (permalink)
Carmagic.us
rothaus's Avatar
Rebuild the pedal cluster for my 1970 911T project.
Here the before
Here after the pan piece blasted and coated and with new bushings.
And ready for the time of installation.
Cheers
Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 07-03-2016, 09:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5673 (permalink)
JJ 911SC's Avatar
Final look...
I kind of miss seeing the Motor block off plate (post 5644) but installed normally it hided the heating block off plates.
So I spanned it 180 degree (as well as their logo), drilled two new holes at the top and voila...
Old 07-06-2016, 04:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5674 (permalink)
Tug68's Avatar
Stripes!
Tim
87 930:G-50 5 Speed, Powerhaus Headers, K-27, Garretson Intercooler, RarlyL8 exhaust and 1 bar boost....
Gone: 85 911:Wevo shifter,full adjustable suspension,bigger torsion bars,Carbon fiber hood,930 brakes and rims.
Old 07-06-2016, 09:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5675 (permalink)
Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
https://instagram.com/p/BHen9Y6gZMb/
Removed the targa's pan
Old 07-06-2016, 09:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5676 (permalink)
Phoenix's Avatar
Pulled her out of 9 month storage. New registration and thought i was good to go.
For some reason the drivers side turn signals/ hazard are now not working.
All other lights are functioning properly. Driving lights work, passenger signals work, hazards on the passenger side work, headlights hi and low work.
I have noticed the dashboard signal indicators do not light when trying the drivers side signal and both left and right dashboard indicators flash when trying the passenger turn signals.
I've replaced all the fuses and dual filament bulbs, checked for corrosion around fuses and light bulb sockets all to no avail.
Frustrating though this too shall pass.
...Oliver
'73 911T: 2.9ltr w/ PMO EFI
Old 07-06-2016, 10:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5677 (permalink)
1stgear's Avatar
Installed Elephant Racing 80mm studs on the front to match the look of rears after I deleted the spacers. Love the look. Also was needed as I wasn't getting enough lug on the previous studs with the addition of the new wheels.
Old 07-06-2016, 10:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5678 (permalink)
tobluforu's Avatar
Fixed my passenger side window rattle; fixed my loose side mirror, fixed my interior fan that wasn't working (gee, what's this unplugged plug for); tried to fix my falling front hood-installed new struts, what a waste of money and time. Fixed the same hood from opening when going over bumps. Adjusted points, timing, synched stacks, drove car only to find that I have a rear caliper that's dragging. Tried fixing that, but it's seized, new one on order. Rotated wheels, adjusted front camber, raised left front, set toe. This was actually over two days.
Old 07-06-2016, 11:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5679 (permalink)
gumby's Avatar
installed new plugs, cap, rotor, air filter and wires on my 86 3.2 Carrera
Thanks to Pelican Parts and this forum for some great suggestions, and parts
taping the socket onto the extension!
I would like to add a suggestion for extracting and installing the spark plugs without dropping them into the motor, I used the spark plug socket from the old wires.
worked great..no worries
Ron
73.5 T
74 R90/6 (Tupelo Honey)
86 Carrera (Plan B)
1987 BMW K100RS Motorsport
Old 07-10-2016, 09:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #5680 (permalink)
Tags
fuchs are ugly , stock sucks
