Burnin' Rubber
What did you do to your 911 today?
Added outside ambient air temperature sensor and gauge since I am obsessed with correct temp readings. Super accurate!
Took me a while to get the probe in the right spot - to the left of the ride side fog light, tucked under the bumper lip so no direct sunlight to throw off readings. |
Kind of Blue
My driver's seat developed an annoying creak and Silverlock's seat swap inspired me to fix it and get rid of my ugly metal mounting screws and replace them with black screws.
![]() ![]() ![]() I also somehow FINALLY found an irritating 3000 - 4500 RPM rattle after YEARS of chasing it down. The rear grill mesh was rattling against the Clewett rain hats.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
Tell me about it. My rear parcel shelf developed a creak around 3500RPM (harmonics!) and so I’ve gone through and replaced all of the worn self-tappers that hold the 3/4 panels, trim and rear shelf down with fresh black oxide screws + finish washers to tighten it all up.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/ |
Haha, I finally found the clanging noise in my driver side door, the window regulator needs to be replaced and now
I think I am with the noise, that’s a pain in the rear to do, lol
87 Venetian Blue 3.4 |
Coram Deo
Tis the Season (especially with our forecast) to put the summer tires away. In my case, that included buying a new set of tires, Conti Extreme Contact Sport 2. Much more exciting than the regular Michelins that the W124s get...
I think I'm ready for spring.
Dru 1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter • 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio • |
Replaced the receiver dryer, and I’ve got the vacuum pump on it now. It’s been holding a vacuum now for about 2 1/2 hours.
Started to replace the flywheel sensors and CHT sensor, but I ordered the wrong CHT sensor. I don’t want to pull the flywheel sensors through the sheet metal until I get the correct CHT sensor. No driving the car now for a couple days until I get the new part |
I started to measure and drill for a through body sway bar.
76 911S Land Rover 110 Defender |
^^^ Check your clearance between the gas tank and the sway bar. It can get close if off.
I will. My greater concern is the clearance between the sway bar and the brake pipes. As its a Right hand Drive, the pipes cross from the left side of the car to the right. And in that space between the tank and the cabin wall.
I love the straps, looks much nicer than the thing I rigged up.
I trust battery acid isn't going to eat the nylon straps over time. I just tossed out a pair of wok gloves yesterday, pretty sure it was the battery acid from last weeks work. As for my car, checked the battery tender last week and did a little something to keep the weather out of my work area.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Stella's Garage Shift Spring! Such a good move.
I had no idea how badly I needed a new airbox cover until now.
'83 911SC - Rubinrot Metallic IG: @911.sc.83 |
The Dude abides...
@Jaymanbikes13 no words needed I suppose...
Steve '03 Carrera 4S |
Happiest when Tinkering
![]() ![]() Just finished repairing the 2nd gear in this 996 6 speed to adapt it to my 3.2 short stroke turbo engine
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Oil change, new oil filter.
Then replace the rear brake pads. Then, while the car was on the lift, I cleaned a lot of tar off of the bottom of the car along the rocker panels. And I cleaned a lot of dead bugs off of the front valance - spoiler area under the bumper. It is great to sit in my roll around chair and clean at eye level
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
1986 Carrera 3.2 Coupe in Grand Prix White IG: @c.cal.porsche |
Yea, the valance was covered in bugs, as I too hate to lay on the ground to clean the car.
And I did use my 3D printed oil funnel. ![]() With 20-50 oil on a cool day, I started pouring it in with the spout of the of the oil bottle on the bottom, it glugs several glugs, and then I just shove the bottle all the way in, and let go. 100% of the oil empties from the bottle. Right now, only for 3.2 Carreras with the factory air intake. We are hoping to get one designed for a stock SC this weekend.
It was time to get back on the Targa and install the Brey Kraus Targa harness bar. Hopefully less squeaks and rattles when we start driving again.
| Tags |
| fuchs are ugly , stock sucks |
