83 911SC Cab
Added Rennline adj throttle stop to assist recent RSR 917 pedal. Test drive tomorrow.....
83 911 Production Cab #10
Put the engine on the wall. Got to fix a few oil leaks.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Troll Hunter
Finished cleaning the bottom of the 72 and making it ready for reassembly. After 48 years of leaks and mud, I'll be able to spot the inevitable leaks.
Hopefully have it up and running again next week.
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
new engine mounts, and then a long drive before the winter finally comes.
'83 SC Targa '87 944 Turbo '08 Cayman '10 Boxster S |
Finish striping her down. Found out that #2 intake Rocker Arm Shaft was going for a walk...
Pulled out the fresh air blower to examine the blower motor assembly since it was squealing. Spins freely after being cleaned and oiled. I ordered a new Bosch motor anyway and will replace it. Rubber flap material isn't looking very good but I don't see where they are a serviceable part. I may have to make new flaps before reinstalling.
Annual brake service plus new flexi lines and fluid
Sparxdaddy
Ran the Canyons
Current: 2007 c2 TT 3.6 997 Previous: '68 912 1.4 I drive the canyons, PM for meet ups *DECKER CANYON is a NO GO for me*
Guest
Posts: n/a
I took it into the garage I'm building for it for the first time. Trying to decide where everything inside will go.
"Someday very soon, this will all be yours, my pretty!" |
Were those just a straight drop-in without removing the rear deck? How do they sound, and any other upgrades in your stereo? I see they're Infinity, but do you have a reference number?
2018 Porsche 911 GT3 manual 1984 Porsche 911 Carrera Targa 2021 Porsche Macan GTS 2018 BMW R1200GS Adventure Rallye 2020 Ducati Scrambler 1100 Sport Pro |
well, there is a lucky girl :-)
though be reasured, I'd do the same, haha
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
scumbag
Bought some more tools to outfit my 'mini machine shop'.
More hand-built (home built?) parts coming soon.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
'86 Targa (Mighty Mouse) '11 997.2 Carrera S Coupe (To be named) 08 M3 - Sold "Having a sports car that you only take to car shows is like having a race horse you only take to the petting zoo" |
Hbrand
Installing air condition system
Electric A/C
Cheers 1982 Porsche 911SC Euro 1969 Mercedes 280SL 1956 Austin Healey 3x |
rear speakers
https://www.crutchfield.com/p_108R6432CM/Infinity-Reference-REF-6432cfx.html?tp=100 Infinity Reference 4X6 There is a plastic trim that comes glued and fastened to the speakers. Once you remove this plastic trim, the speakers drop right in the rear deck. Taking the rear deck out takes just a few minutes and is pretty easy. But if you dont remove the deck, you just need a stubby phillips screwdriver to access the speaker cover screws. ![]() ![]() I have a stock Blaupunkt Bamberg powering these and the fronts
1983 911SC 1977 930 Turbo (again) 2018 GTS 2023 Audi A4 '74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) Last edited by stevie 77 930; 01-02-2020 at 10:35 AM.. |
Installed Porsche Windshield Decal
Installed new Porsche Decal on Windshield
Put it on the a chassis dyno for the first time since the rebuild.
220 wheel HP at 5700 RPM and a flat torque curve also at 220. I need to get the carbs tuned so that’s the next step. Good start so far though.
84 911 Targa Carrera currently getting renewed |
Installed a couple of fans: The fender mounted oil cooler got an 8" fan from Elephant Racing. It was a tight fit, I had to add a small plate to the mounting bracket to offset the cooler a couple of inches aft so it would clear everything (barely). Replaced the crusty seal around the cooler while I was in there. I also replaced the fresh air fan. The original motor burned out and quit working. The oil cooler fan was a lot more work than I anticipated so no pics, fortunately the fresh air fan was easy.
What did you do to your 911 today?
I drove it like I stole it
![]() Sent from my iPhone using Tapatalk
‘84 Carrera, heavily modded Please follow me @chopped_up_fitness |
| Tags |
| fuchs are ugly , stock sucks |
