I upgraded my wheels from 6 & 7 to 7 & 8 Fuchs. Targa looks a little more aggressive and they fill the wheels wells better.
TBD Prior: '84 911 3.2 Carrera, '83 911SC Targa IG: @heuersandcarreras "I want to use it. That's what 911s are for." - Richard Hammond |
Kind of Blue
Those look great. Good upgrade.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
Rescuer of old cars
Wrapped up a multi-week (and multi-dollar) A/C restoration and upgrade. While my '72 911T started life as a factory A/C car, almost everything was replaced with upgraded parts.
Results were very good, I'm quite pleased...
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 Last edited by Arne2; 08-15-2021 at 04:46 PM.. |
Pelican Parts Vendor
Parked mine next to this rally icon and it got a lot less attention than it normally does. Strange that.
Untitled by Team Illuminata Motorsport, on Flickr
Paul Eddleston BRAID Wheels USA Team Illuminata Motorsport |
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
1979 911 SC
I replaced the temperamental starter on my 79' SC with a High Torque starter from our host. What a bear! That top barrel not is a PITA to reach! I couldn't even see it without the help of a mirror. She fires right up now with authority! I also installed my MOMO Indy with an eccentric hub so it improves the view of the gauges. Successful weekend of wrenching all around!
How about "What has your 911 done for YOU today"
When life gives you a swift kick in the nuts, not much else puts a smile on your face like a great drive with a wonderful woman in an incredible 911 that you built piece by piece. ![]()
1978 SC Targa |
1979 911 SC
Solamar, good idea!!
Rebuilt my calipers and replaced the pads. I also ordered a Viair tire inflator from 4wheelonline because my HF one has seen better days.
Kind of Blue
Changed the driver's side hood strut last night. Pelican and its hemostat trick turned what could have been an hour of cursing into a 5 minute job. So that felt good.
cycling has-been
Replaced the in-tank fuel inlet screen on my '76.
PITA job, mainly because you must start with an empty tank. FWIW, when the indicator needle is half way between 1/4 tank and the 'reserve' warning light - there is still 5.5 gallons in the tank. PITA, also that I had to make my own 22 mm allen wrench. (I later saw one on Amazon for around $10.00 + S+H. A couple of reference threads here said they were not available - but they are.) Now I sleep at night knowing that 45 years of accumulated crap (20 years of that span sitting in a garage) is no longer in the inlet stream. Bill K ![]() ![]() ![]()
73 911T MFI, 76 912E, 77 Turbo Carrera |
Won an award!
Untitled by Team Illuminata Motorsport, on Flickr Untitled by Team Illuminata Motorsport, on FlickrMost lights!
The old screen looked perfectly clean. Just discolored.
1986 Bosch Icon Wipers coupe. |
Enginerd
Mine looked pretty much just like it, but once it's out, you're not going to put it back in....whether it's clean(ish) or dirty....
1982 Guards Red 911SC, 1994 Riviera Blue RoW 993, 2020 British Racing Green Macan GTS Gone but not forgotten: 2017 GT Silver Turbo S, 2012 Guards Red 991.1 C2S, 2017 Carrera White Macan GTS IG: @pcar911fan |
cycling has-been
Absolutely correct - that was not my problem, the car is still stumbling on the open road
![]() ...on to the new fuel pump to see if that cures it. Bill K
Mounted a Russian mig clock, because it’s cool.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
76 911S Land Rover 110 Defender |
| Tags |
| fuchs are ugly , stock sucks |
